Author Topic: what tyre for 19's  (Read 5348 times)
Offline iainalpine
what tyre for 19's
« on: April 21, 2009, 04:07:00 pm »
hi guys, have just got bought a set of 19" oettinger rz splits for the car and was wondering what size of tyre to go with. either the 225 or the 235/35/19.
what are you guys running on here and are there any problems with the 235's hitting the arch.
full spec of the wheel is 19`x 8.5' 5x112 et35.
cheers
Iain :happy2:
2006 MKV GTI, DSG, Stg2 Revo map, VWR front splitter, KWv3's, Eibach rollbars, Walk kit, Carbonio induction kit, Full Milltek exhaust system, Forge FMIC
Offline markymark
Re: what tyre for 19's
« Reply #1 on: April 21, 2009, 04:12:43 pm »
Ooooh that ET is not good, you are gonna have to mod the arch I would say. The standard wheel is 7.5J ET51,check out this wheel calculator to see how much pokeage you will get http://www.1010tires.com/WheelOffsetCalculator.asp
« Reply #2 on: April 21, 2009, 04:36:54 pm »
i agree, i think you might have clearance issues
but 235 would be my normal choice
« Reply #3 on: April 21, 2009, 06:40:58 pm »
Your gonna need 215, plus a touch of camber to tuck them under, other wise your gonna have to sit very high.  :smiley:
Offline MongyUk
« Reply #4 on: April 21, 2009, 07:01:28 pm »
I have 215's on my wheels (same spec) with it lowered quite a bit and find that the wheels are fine.
Offline celica
« Reply #5 on: April 21, 2009, 07:41:01 pm »
nice choice of wheels i had these on the tt and loved them
for the golf i'm not sure
but personally if i ran 19's i wouldn't like to run on less than 235/35/19's i had
MKV Golf DSG
Offline iainalpine
« Reply #6 on: April 21, 2009, 08:01:56 pm »
MONGYUK and anyone else who is running 215/35/19 tyres, what model of tyre do you find works best for you? stretch etc.
As for arch work, what normally gets done? who is doing it and how much is it costing?
thanks for your help guys
Iain
« Reply #7 on: April 21, 2009, 09:14:33 pm »
Iain
Your new wheels will be sitting 28mil further out than a monza II. that means you will have a bit of poke, you can adjust the camber on the back a bit, whether you would want to is another matter you get excessive tyre wear depending on how much you put on.
on the front You can get the lip of the arch pinned in and the wheel liner moved up, but again i dont think this will be enough, but i am not sure, again you can buy camber adjust top mounts to tuck them in far enough, but tyre wear pops up its head again.
After this your talking £££ to get arch work done.  :happy2:
Offline MongyUk
« Reply #8 on: April 21, 2009, 09:46:58 pm »
Iain
Hi Iain,
As topcat said you will have to pin back a clip on the front wheel arch (you can do this yourself) after this you should be fine.
The tyres I use at the moment are Falken 452's
from here    http://www.camskill.co.uk/products.php?plid=m4b0s76p0
But i would recommend the P Zero Nero.
Hope this helps.
Offline iainalpine
« Reply #9 on: April 22, 2009, 07:37:08 am »
MONGYUK AND TOPCAT, thanks for the info. im a little concerned about the buffing issue and really dont want to go down the route of rolling arches etc. the one thing in my favour is that im not going to be decking the car out as low as it can go. was looking for a slighlty lower stance compared to standard.
will keep you guys updated on whats happening with them.
thanks again
Iain
Offline bennylenny88
  • needs moar lowwww
« Reply #10 on: April 22, 2009, 03:45:53 pm »
i got 235s and its pretty rough atm as it is.. i couldnt imaging 215s  :scared:
Offline iainalpine
« Reply #11 on: April 22, 2009, 04:21:52 pm »
Hi bennylenny88, what do you meen by being rough?
cheers
Iain
  • needs moar lowwww
« Reply #12 on: April 22, 2009, 04:35:19 pm »
when you go over bumps its really tough.. as in its a lot stiffer.. if that makes sense..  :confused:
Offline joesgti
  • Eat my sick, Eat my sick.
« Reply #13 on: April 22, 2009, 05:01:33 pm »
You need STREEEEEEEEEEEEEEEEEEEETCH  :drool: :drool:
Offline iainalpine
« Reply #14 on: April 23, 2009, 07:21:38 am »
ahhh, i understand now.  :rolleye: :embarrassed:
