Author Topic: Which Blurtooth module do i need for Blackberry and iPhone  (Read 2105 times)
Offline SeanB
« on: February 03, 2012, 07:50:52 pm »
Sorry for all the questions.
I have now retro fitted an RNS510 into my ED30 and the next thing I want to do is fit the OE Bluetooth. I heard that the early BT module wouldn't work with new blackberry or iPhone, so is there a certain one I need? I am guessing the only other bits I need will be the cable to connect it to the RNS510 and a microphone??
Does anyone do a kit?
Thanx
Sean..
Offline SteveP
  • -Given: 117
  • -Receive: 341
    • My Project
Re: Which Blurtooth module do i need for Blackberry and iPhone
« Reply #1 on: February 03, 2012, 07:55:03 pm »
Do you have the Highline cluster?
Offline SeanB
« Reply #2 on: February 03, 2012, 10:46:54 pm »
Sorry, but I don't know. What does that bit do and how do I figure out if I have one or not??
Offline Nodz
  • -Given: 73
  • -Receive: 103
« Reply #3 on: February 04, 2012, 06:24:12 am »
What is meant by highline and midline is the type of info screen between your rev counter and speedo.
Found this post by deako that's shows it easier
Midline:
Highline:
Depending on what you have and what functions you require, ie if you have highline do you want all the info displayed on there or not will decide what Bluetooth kit you need as VW loads and it depends on what yor after
HTH :happy2:
Offline SeanB
« Reply #4 on: February 04, 2012, 08:43:36 am »
Thanks Matey.
OK, I have the Highline and I guess I would like the BT to be as fully integrated as possible. I also have the multi function steering wheel, if that makes a difference.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #5 on: February 04, 2012, 08:59:41 am »
The Skoda 729B is your best bet if you want it to display in Highline and RNS510
Cluster and Key coding
Location Great Yarmouth
Offline ILoveTuna
« Reply #6 on: February 04, 2012, 09:37:40 am »
What about for midline whats the recommendation?  :happy2:
Offline Nodz
  • -Given: 73
  • -Receive: 103
« Reply #7 on: February 04, 2012, 05:53:43 pm »
I've just had installed a 7P6 035 730G with my midline and rns 510 and it works a treat :happy2:
