Author Topic: loss of power  (Read 1986 times)
Offline boxxer1973
loss of power
« on: February 05, 2012, 10:26:30 pm »
was driving home just now, pushed the car felt it hesitate so came off power then pushed throttle again and hesitated then all revs dropped and wouldn't go over 3000 revs, recently upgraded to stage 2 revo have milltek turbo back ths fmic and itg intake. the fault cleared after about 30 seconds and is normal again. Any ideas please ?
Mk5 golf Gti REVO. stg2+
Milltek | Auto tech | White line | Forge | REVO | KW | Quaife | helix clutch |
Offline edd666999
  • -Receive: 89
Re: loss of power
« Reply #1 on: February 05, 2012, 10:30:02 pm »
Coil pack.
Scan via vcds might show missfire on the cylinder effected
Offline boxxer1973
Re: loss of power
« Reply #2 on: February 05, 2012, 10:36:49 pm »
Only had them all changed at Vw 6 months ago I'll scan in the morning
Offline boxxer1973
Re: loss of power
« Reply #3 on: February 05, 2012, 10:42:28 pm »
looks like i need a pump
004195 - Fuel Pressure Regulation: Control Range Not Reached
               P1063 - 002 - Lower Limit Exceeded - Intermittent
             Freeze Frame
                    Fault Status: 00100010
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 125012 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 21:58:03
  • -Receive: 453
Re: loss of power
« Reply #4 on: February 05, 2012, 11:06:04 pm »
When did you last check your cam follower?
Offline edd666999
  • -Receive: 89
Re: loss of power
« Reply #5 on: February 05, 2012, 11:06:27 pm »
Offline boxxer1973
Re: loss of power
« Reply #6 on: February 06, 2012, 04:02:20 pm »
Had a poke about under the bonnet and found the pcv like this
