Author Topic: Alternative to RNS510  (Read 8649 times)
Re: Alternative to RNS510
« Reply #15 on: February 19, 2012, 10:39:37 am »
I havent found any at £300, let alone £200 so I guess I need to keep looking..
Deako meant he got his for £600. You are not going to find a new RNS for under £500 and een used ones go for £200-400.
Offline Aweful_Truth
« Reply #16 on: February 19, 2012, 01:29:33 pm »
had a alpine ine s900r fitted 2 weeks ago,comes with sat nav and blue tooth built in
Where did you get the facia adaptor from? Thanks :)
To Bad, So Sad, Bye Bye!
« Reply #17 on: February 19, 2012, 02:07:08 pm »
Chris at Chorley audio fits then as standard as they are a better fit
give him a ring and he will sort you one out
 http://www.chorleycaraudio.co.uk/
Offline boulevard
« Reply #18 on: February 27, 2012, 08:09:51 pm »
I have found a rns510, its version C. Am I likely to suffer the battery drain issues, its going into an 06 GTI?
Black GTI Mk5 - got cruise, RNS510 & Carbonio intake to be fitted next..
« Reply #19 on: February 27, 2012, 08:11:41 pm »
Probably. You need to know your canbus version.
« Reply #20 on: February 27, 2012, 08:19:49 pm »
Ive started thinking of upgrading to something like the Vw Nav / hdd unit but the Golf R Nav took a bizzarre route compared to the Tom Tom the other night?  :confused:
Offline boulevard
« Reply #21 on: February 27, 2012, 08:24:33 pm »
Can I check this physically or do I need to find someone with VCDS?
« Reply #22 on: February 27, 2012, 08:29:10 pm »
Vcds
Offline boulevard
« Reply #23 on: February 27, 2012, 08:37:36 pm »
Is there a rule of thumb, e.g you need canbus version x with RNS510 version C etc?
My local garage have kit to read error codes so I will give them a call tomorrow to see if they can find out what version I have.
