Author Topic: Engine power is getting cut *FIXED*  (Read 11633 times)
Offline ktlstar
Re: Engine power is getting cut
« Reply #45 on: February 25, 2012, 07:21:20 pm »
It's cool, oh dear so i guess its easily to damage it!!
I l hear back from PDT but yeah i aswel now think its te pump!!    Cheers bro
- #1240 ED30 Revo STAGE2+
- Southeast - Vag Com owner
  • -Receive: 453
« Reply #46 on: February 25, 2012, 07:25:33 pm »
There was an update to the LPFP in the past to help sort out a cold starting issue so I suspect your mate had an early year model GTI.
I suggest you first change your fuel filter before shelling out the big buck for the pump and redo your logs.
Offline ktlstar
« Reply #47 on: February 25, 2012, 07:33:45 pm »
Yeah i guess so fella! Cheers.
Offline PDT
  • -Receive: 142
« Reply #48 on: February 25, 2012, 11:18:10 pm »
Sorry for the delay replying to your email, i have literally just sat own at 11.15pm after being on the dyno ince 9am.
From what I have seen in your email it seems a fault with the low pressure fuel supply, change the fuel filter and see if that helps. (not likely but worth a try as a process of elimination)
Will take another look over your logs tomorrow hen I can see/think properly.
Dave.
Offline ktlstar
« Reply #49 on: February 26, 2012, 08:08:13 am »
Dave,
No need to apologies, I highly appreciate you helping.
I'll get hold of a filter + Pump Tuesday.
Thanks!
Offline ktlstar
« Reply #50 on: February 27, 2012, 05:29:12 pm »
Fuel filter changed and........ I think it has worked!   I managed to get the wheelspinning in second without no power cut!
I will try on way home tonight if its fully sorted it out!
« Reply #51 on: February 27, 2012, 05:41:28 pm »
fingers crossed it worked :happy2:
Offline heavyd
  • -Receive: 29
« Reply #52 on: February 27, 2012, 07:40:32 pm »
At least it was the cheaper out of the two possible causes :happy2:
  • -Receive: 453
« Reply #53 on: February 27, 2012, 08:10:00 pm »
Great news...  :happy2:
Offline ktlstar
« Reply #54 on: February 27, 2012, 09:59:54 pm »
PROBLEM SOLVED  :congrats: Fuel filter was the culprit!
Currently on stock Revo settings from removing the battery, but no fuel cut during my way home from work!
I thank you all who put there time to posts on this thread to help me out!
Now is it the case of putting the rs4 valve back on or just sell it ? Do i really need it ?
  • -Receive: 453
Re: Engine power is getting cut *FIXED*
« Reply #55 on: February 27, 2012, 10:38:06 pm »
I would put the valve back in as the slightly higher cracking pressure gives your injectors a little extra headroom.
Offline ktlstar
« Reply #56 on: February 27, 2012, 10:45:02 pm »
lol, i dont want to fubar anything again! DOH!
Offline Gti_Mad
« Reply #57 on: February 27, 2012, 11:24:49 pm »
can u give me the part number plz  :happy2:
Offline ktlstar
« Reply #58 on: February 27, 2012, 11:28:53 pm »
079 130 757 - rs4 valve
Offline ktlstar
« Reply #59 on: February 27, 2012, 11:41:46 pm »
think i might sell mine for time being! so if your after it pm me ;)
