Author Topic: ITG intake fitted  (Read 2876 times)
Offline xjscx
ITG intake fitted
« on: February 25, 2012, 12:55:47 pm »
Just finished fitting my itg intake. Can feel the difference over the Carbonio which the car came with.
All went well apart from cracking my engine cover when removing it  :ashamed:
  • -Receive: 453
Re: ITG intake fitted
« Reply #1 on: February 25, 2012, 01:03:05 pm »
Sweet but you need to realign your oil cap if it's not loose.
Offline mkviken
« Reply #2 on: February 25, 2012, 08:35:56 pm »
fitted a ITG maxogen on the mk6 and it makes a whistle noise above 4000rpm.
anyone know how to reduce this?
Offline xjscx
« Reply #3 on: February 25, 2012, 08:59:59 pm »
Mine dosent whistle. Have you checked all the jublee clips, might have a leak somewhere
Offline mkviken
« Reply #4 on: February 25, 2012, 09:10:06 pm »
yeah everything is tight and the pipe is sitting flush and as far up on the MAF as possible
its a kind of squeak/whistle high pitched noise
Offline 56OctyVRS
  • -Receive: 72
« Reply #5 on: February 26, 2012, 06:06:32 pm »
It might be the sound of the turbo spooling up. I had a high pitch squeel when I had my intake fitted when under wide open throttle.
Offline mkviken
« Reply #6 on: February 26, 2012, 07:43:08 pm »
well i can hear the turbo spooling up much louder now even when just feathering the throttle at a steady tow speed. i get a slight whoosh when lifting off too which i would have expected and don't mind but the squeal is a bit much.
I've had a look on a few forums and its a pretty common topic but i didn't expect the VWR/ITG intake to sound this 'unrefined' especially with it being a closed air box type.
i bought it used so decided to take it off and clean and oil it today anyway
