Author Topic: Whistling sound coming from engine, is this normal...  (Read 1516 times)
Offline ConeKiller
« on: March 03, 2012, 12:07:31 pm »
Hi everyone
When i accelerate i get a whistling sound from the engine, can hear it right from low revs up to high and it gets louder, with the windows down its really obvious.
I know at high boost when you let of the accelerator it makes a whoosh as normal but im not sure on the whistling, im sure it wasn't like that when i bought it.
Any advice? from what ive read so far im guessing its the diverter valve?
cheers in advance
« Last Edit: March 03, 2012, 12:09:38 pm by ConeKiller »
Offline Nodz
  • -Given: 73
  • -Receive: 103
Re: Whistling sound coming from engine, is this normal...
« Reply #1 on: March 03, 2012, 02:14:37 pm »
Sounds like the dv has a split in it as I had the same on mine. If you've got an ED30 only takes 5 mins to check, if standard GTI takes a bit longer due to being in a different position
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 249
« Reply #2 on: March 03, 2012, 06:53:25 pm »
I get a whistling sound from mine too - I put it down to the turbo spooling up. As Nathan said - get the DV checked / replaced though first :happy2:
