Author Topic: idle problem  (Read 1459 times)
Offline Dario
  • booosting... :)
idle problem
« on: March 07, 2012, 01:39:09 am »
I have a problem with my GTI
on Idle it produces missfire,not all the time ,doesnt idle perfect ,but when driving no problems or missfires
the car is now on original map and OEM sparks,new coil packs ,only modifications are twincooler,twintake,catch can ,milltek TBE and autotech fuel pump
anyome had similiar problems? ,all sensors are check and work properly ,could it possible be the ECU ? at the dealership they told me that the ECU can be faulty without showing on the diagnostics ,something with not keeping the voltage at idle or something like that
REVO ST2+ Edition30 -sold
soon 2015 Golf R :)
  • -Receive: 453
Re: idle problem
« Reply #1 on: March 07, 2012, 08:38:43 am »
You really first need vcds to check which cylinder you're getting the misfire from, then, work from there with troubleshooting the issue.   :smiley:
Offline 56OctyVRS
  • -Receive: 72
Re: idle problem
« Reply #2 on: March 07, 2012, 03:13:15 pm »
No engine will idle perfectly and will have the odd hiccup every now and again. Mine does but its normal.
Offline Dario
  • booosting... :)
Re: idle problem
« Reply #3 on: March 07, 2012, 06:26:04 pm »
random on all 4 cilinders
2: 56OCTYVRS : yes thats right a hiccup sometimes ,so its normal ?
soon 2015 Golf R :)
