Author Topic: S3 intercooler plastic end and metal end - Differences  (Read 21972 times)
Offline the bruce
  • -Given: 322
  • -Receive: 101
    • my GTI
Re: S3 intercooler plastic end and metal end - Differences
« Reply #15 on: March 28, 2012, 01:35:24 pm »
Heat resistance isn't the point. Thermal conductivity of all plastics is very very bad.
Unfortunately we aren't able to specify the differences in cooling and flow. APR
and others may have compared them. Feel free to search some data on the web.
No doubt the thicker core is better if you have a K04. But no doubt as well the 'old'
S3 full alloy IC has better cooling properties. And if I take the labour to swap the IC
I'd surely go for the better one. To me the newer hybrid IC isn't worth three hours
of work.
"You get what you pay for."
Offline Sammy
« Reply #16 on: March 28, 2012, 01:43:47 pm »
I got mine for £120 delivered as new condition, And to be honest i also dont see the plastic ended ones being a problem really, All the golf R's, TT's and Mk6 GTI's are coming with them and when tuned they seem to be fine?
GTI MK5 with all the gooodies
K04 power going on soon!
Offline the bruce
  • -Given: 322
  • -Receive: 101
    • my GTI
« Reply #17 on: March 28, 2012, 03:02:05 pm »
I didn't say it's "a problem". I did say the full alloy S3 IC has better cooling properties.
Even the stock Mk.V GTI IC isn't any issue.
But why take the labour for such a tiny improvement? Make your own decision - it's
your time to spend.
 :wink:
Offline 56OctyVRS
  • -Receive: 72
« Reply #18 on: March 28, 2012, 03:09:11 pm »
Just been researching the differences on various american forums and they report no difference in the cooling characteristics as the core is the same and no impeded flow.
My point about the plastic end caps is that they will not absorb heat as much as the aluminium (not alloy) end ic when driving slowly in town traffic. I know plastic wont cool air flow but it wont allow it to get warmer than metal would either.  Thats why they dont make air boxes out of metal, as they would just be a big heat sink with engine temps.  So to some its a cost option but I dont see as its a real problem.  After researching they use these as standard over in South Africa and they have much hotter conditions than us and dont report anything bad about them.
Id just stick the plastic ended ic and not worry too much about it Sammy.
Offline Sammy
« Reply #19 on: March 28, 2012, 03:28:08 pm »
Thanks, I did read about various posts which were similar to the ones you have just said, It does make sense as long as the intercooler core size is the same as the alloy ended intercoolers then i really wont see much difference in both coolers
« Last Edit: March 28, 2012, 03:33:00 pm by Sammy »
Offline Sammy
« Reply #20 on: March 28, 2012, 03:37:22 pm »
Also this is the part number i have:
1K0 145 803 BP
Came from a mk6 GTI and i believe this is the same as the S3 intercooler (plastic ends)
Will i need different hoses to connect them to as opposed to the metal ended coolers?
Offline the bruce
  • -Given: 322
  • -Receive: 101
    • my GTI
« Reply #21 on: March 28, 2012, 07:21:08 pm »
Mk.V airboxes are placed inside the warm engine bay. The IC is placed in front of the radiator.
It's only job is to cool air. So it does make sense to make it from a material of proper thermal
conductivity. That's why the core is alloy. That's why high grade ICs are made of alloy com-
pletely. There is no advantage on plastic other than cost savings. Have a look at APR, Forge
or THS ICs. They have alloy ends. Audi won't have made the old S3 IC full alloy if there would
no advantage. It's nothing new they make things worse to save some cents.
Offline daz_pd
  • My VRS
« Reply #22 on: March 28, 2012, 07:43:14 pm »
Im going to take a chance on one of these plastic ended ones, I can understand the Alloy end tank version would be better, but I doubt the difference would be noticable in our climate.
Offline 56OctyVRS
  • -Receive: 72
« Reply #23 on: March 28, 2012, 08:23:43 pm »
The point im making is the end caps dont do anything to cool the air. Thats down to the radiator fins and the core, not the end caps. So it doesnt matter if they are plastic or metal, as they both ic cores will cool the charged air the same. There is no advantage over fitting the all alumininium ic to the one with plastic end caps. The ic is still in the engine bay on our cars and not a true front mounted intercooler like on evo where you can see them exposed in the bumper.
Offline the bruce
  • -Given: 322
  • -Receive: 101
    • my GTI
« Reply #24 on: March 28, 2012, 08:48:58 pm »
When there aren't any differences so why swap the IC? Why don't you stay
with the stock IC? It's paid for and it doesn't need any labour.
Ok, then all the engineers who designed the best ICs must be complete idiots?
 :signLOL:
Offline Sammy
« Reply #25 on: March 28, 2012, 09:07:25 pm »
Because he is still upgrading to S3 intercooler like me and that has a bigger core and will have benefits
Offline 56OctyVRS
  • -Receive: 72
« Reply #26 on: March 28, 2012, 09:34:30 pm »
Do end caps cool the air? No. There purpose is to guide the air in and oit of the radiator core. Thats all.
Offline the bruce
  • -Given: 322
  • -Receive: 101
    • my GTI
« Reply #27 on: March 29, 2012, 03:51:10 am »
Ok, it's pointless. You know it (better of course). And I don't have the time to repeat my self.
You both are looking for the answers you like to hear. If so you better don't ask.  :wink:
Offline 56OctyVRS
  • -Receive: 72
« Reply #28 on: March 29, 2012, 01:46:43 pm »
The point of the thread was to compare the differences between the metal and plastic ended s3 intercoolers. After research and reading about other peoples experiences on other forums , the conclusion was that they gave the same performance. Irrespective of what end caps they were. Im sorry if you dont agree but end caps dont cool the charged air. I know that as many moons ago when i first started tuning turbo cars.  A very well known company who produces ic explained to me how the ic was put together and what each part did.
Offline the bruce
  • -Given: 322
  • -Receive: 101
    • my GTI
« Reply #29 on: March 29, 2012, 04:05:35 pm »
You said two or three times that plastic would have advantages. I wonder
why another member gave you a 'thank you' for this complete nonsense.  :jumping:
