Author Topic: How to switch air con on?  (Read 2095 times)
Offline Rustybear
  • -Given: 243
« on: March 27, 2012, 07:34:50 pm »
Ok I know I am dumb but I am used to cars with an ac switch. How the hell do you switch air con on in a mk5 gti?????
Offline sanj
  • -Given: 17
Re: How to switch air con on?
« Reply #1 on: March 27, 2012, 07:37:31 pm »
Make sure the A/C light is it(2008/on)  or Econ light is not lit(on my 2007 it's a little confusing),well that's how it work's on mine! :smiley:
« Last Edit: March 27, 2012, 07:39:54 pm by sanj »
Offline Rustybear
  • -Given: 243
« Reply #2 on: March 27, 2012, 07:51:55 pm »
Thanks. Mine a 2006 so i ensured econ is off and no cold air???
Offline sanj
  • -Given: 17
« Reply #3 on: March 27, 2012, 08:15:03 pm »
Might need regassing(not sure if i'd spelt that right!)or even worse the MK5's have a tendency to screw up the air con compressor!
« Reply #4 on: March 27, 2012, 08:17:51 pm »
Depending what heating system you have but on my duel zone you turn the settings to lo
MPS
« Reply #5 on: March 27, 2012, 08:23:03 pm »
Econ = Economy mode, ie it turns the compressor off disabling the air-con. So its effectively just a fan.
Offline Rustybear
  • -Given: 243
« Reply #6 on: March 27, 2012, 09:18:58 pm »
Makes a funny noise coming from the vents when I put auto ob? Does this mean compressor fail then??
Offline v2brett
« Reply #7 on: March 27, 2012, 10:29:28 pm »
yeah mine did this when the gas was low, it was kind of groaning noise mine had.  hopefully low gas and maybe a leak and not the compressor failure problem
Still Here!
Offline Deedub
« Reply #8 on: March 29, 2012, 04:16:31 am »
Had similer on mine (duel zone), went for a re-gas and found it had a big leak and an electrical problem, was fixed in the end though without a compressor replacement (which can be VERY expensive!).
mines a 2007, and was completely empty due to the leak.
