Author Topic: Ester based engine oils - overkill for road use or not?  (Read 1334 times)
MPS
« on: April 06, 2012, 07:25:40 pm »
Noticed opie have these for sale at slightly dearer prices to quantum III and the like, and are supposed to provide better protection against shear forces, etc. Anyone use ester based? Discuss
Offline chungster
Re: Ester based engine oils - overkill for road use or not?
« Reply #1 on: April 06, 2012, 07:46:20 pm »
Most of the Silkolene range is ester based and in the Subaru world that stuff is gold.
But not sure if they are VW approved though
Offline martziniuk
« Reply #2 on: April 06, 2012, 07:57:50 pm »
Millers CFS here.
They're more expensive for a reason but tbh I'm thinking of buying one of the cheaper ester synth oils and changing more often.
Offline vRSAlex
  • -Receive: 253
« Reply #3 on: April 06, 2012, 09:49:44 pm »
Go for the cfs 5w40 nt.  It's their new nanotech version and works very well in the tfsi engine.
Follow AKS tuning on Facebook
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #4 on: April 06, 2012, 10:17:30 pm »
I think I'm in the overkill camp to be honest.
How would you know how well your oil is/was performing?  You really can only accept the marketing blurb and continue blindly assuming all is well.
I can hand on heart say that for an oil to get an OEM approval it has to go through a lot of testing.  I've been to the TOTAL research centre at Solaize and seen the dyno rooms with new engines on test.  In the marine environment we normally get about 6000 hours (Typically a year) of testing and obviously satisfactory results before the OEM will give us an approval.
Stu...
Offline robern2
« Reply #5 on: April 07, 2012, 10:17:24 am »
grade 5 ester based stock is one of the best. I've been using silkolene pro s 5 - 30 for the past few years. Car runs perfectly.
