Author Topic: Battery removal & Revo  (Read 2381 times)
Offline edition_30
« on: April 11, 2012, 09:59:46 pm »
I need to disconnect my battery for no longer then a minute. Was wondering will I loose my revo settings?
Re: Battery removal & Revo
« Reply #1 on: April 11, 2012, 10:12:48 pm »
i would think it will loose the settings
« Reply #2 on: April 11, 2012, 10:20:52 pm »
It should revert to stock Revo settings.
Offline edition_30
« Reply #3 on: April 11, 2012, 11:10:10 pm »
Will I need a select plus switch to reapply the settings?
Also when connecting the switch will it show default values opposed to the values I was running?
« Reply #4 on: April 11, 2012, 11:13:37 pm »
Unless you know your current values, when you log in with the SPS switch, it will show B1T1F1 or whatever stock is. You will then need to set it to what it was before. Whoever did your remap should be able to tell you this. I was told my settings at the time the map was applied.
« Reply #5 on: April 11, 2012, 11:23:58 pm »
When you disconnect the battery the map sets back to Revo's 'stock', but when you use the switch to reload the 'Revo' remap, it will load the same Revo B/T/F settings you had previously. So no problem or visit to a Revo dealer necessary.
If however, your VW dealer flashes your ECU with an update it will effectively cancel your Revo remap so you would then need to have that reinstated. Some Revo agents charge a small fee for this and others don't. If they don't already know you, you may have to prove ownership of the Revo licence.
Offline edition_30
« Reply #6 on: April 11, 2012, 11:36:57 pm »
I have had the remap for some time but only this weekend had my settings changed to  Boost 8 Timing 5 Fuel 9. This was not done by the dealer but my car felt so smooth. So are we saying that anybody with an sps switch will be able to apply the above settings for me?
« Reply #7 on: April 11, 2012, 11:38:57 pm »
Yes.
Offline edition_30
« Reply #8 on: April 11, 2012, 11:40:05 pm »
Cheers guys
