Author Topic: Is K03 discharge pipe same as K04?  (Read 3134 times)
Offline Robo
« on: April 12, 2012, 08:42:33 pm »
Is the left hand side dicharge pipe the same diameter on the K03 as the K04? As in the end that accepts the left hand intercooler hose?
  • -Receive: 453
Re: Is K03 discharge pipe same as K04?
« Reply #1 on: April 12, 2012, 10:01:29 pm »
Apart from the silicone hose that attaches to the turbo the rest of the pipe is the same.
Offline martziniuk
« Reply #2 on: April 12, 2012, 10:07:50 pm »
The lugs which hold the rubber intercooler pipe in place will be wrong.
Offline Robo
« Reply #3 on: April 13, 2012, 10:53:50 am »
Basically I bought an intercooler kit for a mk5 Gti thinking it would fit but the connector on the drivers side is a smaller diameter insert than the discharge pipe  I thought then with mine being edition 30 the K04 discharge pipe must be bigger
Offline gazon69
« Reply #4 on: April 13, 2012, 10:57:09 am »
Connector into intercooler are same on k03 + k04 as they share the same standard cooler anyway.
Offline martziniuk
« Reply #5 on: April 13, 2012, 12:50:15 pm »
Ahh. In that case I'd probably sell it on unless you can fabricate some custom pipe work, but then you don't want to reduce the air flow with smaller connection.
Edit: if it's the kit I think it is with the removable end, you may be able to get a connector seperatly?
« Last Edit: April 13, 2012, 12:54:26 pm by martziniuk »
Offline Robo
« Reply #6 on: April 13, 2012, 02:16:45 pm »
I don't want to sell it on and cause someone else the same problem so I am looking into it with the supplier to see if they have sent me a wrong part :) also I agree with reducing the air flow don't want to step it down to a small diameter pipe
