Author Topic: sixth gear  (Read 1852 times)
dockermel
sixth gear
« on: April 13, 2012, 06:53:19 am »
hi my golf is surposed to be a stage two remap(previous owner no paperwork to confirm this) it dosent seem to have a lot of pull in sixth gear and runs out of steam at about 120-130mph. is this normal?? :confused:
  • -Receive: 453
Re: sixth gear
« Reply #1 on: April 13, 2012, 08:52:05 am »
A k03 tends to run out of puff starting around 5k rpm.
Offline gazon69
Re: sixth gear
« Reply #2 on: April 13, 2012, 09:05:34 am »
On a stage 2 you should pull to 150mph without too much effort. May have boost leak, faulty dv, faulty pcv, or something else. Get codes read.
Offline Black9
  • -Given: 35
Re: sixth gear
« Reply #3 on: April 13, 2012, 09:40:53 am »
Or maybe it's not stage 2 & that's why it isn't pulling hard in sixth. Best bet is to get it on a RR & measure the power that way. Then as mentioned check for boost leaks etc....
Offline Kregiel
  • -Given: 28
  • -Receive: 20
  • Supersonic
Re: sixth gear
« Reply #4 on: April 13, 2012, 11:33:53 am »
are we talking stage 2 on gti or ed30?? on gti above 130 mph it would be some effort but ed30 should be effortless enough
