Author Topic: How to test a diverter D to know if its faulty?  (Read 4432 times)
Offline Sammy
« on: April 14, 2012, 04:49:50 pm »
Recently i have been feeling reduced performance and MPG and i cant be sure but sometimes i get a hesitation when on boost so maybe diverter, How would i know if it is leaking boost or not?
GTI MK5 with all the gooodies
K04 power going on soon!
Offline Thor
  • -Receive: 25
Re: How to test a diverter D to know if its faulty?
« Reply #1 on: April 14, 2012, 06:20:21 pm »
You really need some one to scan with VCDS / do some logs.
It may be that you have a coil pack on the way out.
                                     Mk6 GTI
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 249
« Reply #2 on: April 14, 2012, 06:27:38 pm »
Or smoke test it? All good tuners have the ability to run smoke though your boost system  :happy2:
Offline Geoffcarragh
« Reply #3 on: April 15, 2012, 12:59:08 am »
when the rubber DV's fail you can hear a whistling noise (like air escaping from a balloon) when the turbo kicks in.
Easiest to hear the noise under hard acceleration in 2nd and 3rd gear.
Or you could take it out and have a look. this means getting under the car for the early K03 engines, but its at the top on K04 cars.
'05 Silver, 5 door, 18'' Monza II, Leather, Lux Pack, Gear Stick, CD changer in armrest, colour coded rear bumper, upgraded DV,
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 249
« Reply #4 on: April 15, 2012, 01:17:59 am »
Hard to tell on the Revision D DV as there's no rubber to burst and the leaks are more subtle (air escaping down the side of a piston).
VCDS logs are probably the best way to do it without taking it off and smoke testing it.
Offline Sammy
« Reply #5 on: April 15, 2012, 01:42:53 pm »
What is the method of using VCDS to test a diverter valve, I know someone that has it but he's a total amateur
Offline ktlstar
« Reply #6 on: April 15, 2012, 02:07:45 pm »
you measure boost pressure vs specified pressure will give you a hint, however if showing low could be many other reasons i.e boost hose leak.  :happy2:
- #1240 ED30 Revo STAGE2+
- Southeast - Vag Com owner
