Author Topic: New canbus benefits?  (Read 1262 times)
Offline edition_30
« on: April 29, 2012, 02:28:11 pm »
I purchased a new canbus when fitting my rns, turns out I didn't need it as mine does not suffer from the battery drain issue.
Apart from the drain issue are there any other benefits to fitting such as firmware updates etc as I'm debating wheter or not I should install.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: New canbus benefits?
« Reply #1 on: April 29, 2012, 02:32:13 pm »
If you don't need then you can sell it
or if you intend to fit a Polar FIS it might benefit from changing it
Cluster and Key coding
Location Great Yarmouth
  • -Receive: 453
« Reply #2 on: April 29, 2012, 02:33:25 pm »
Do you have the latest firmware on your unit?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #3 on: April 29, 2012, 02:45:44 pm »
The unit is an H unit with 3970
