Author Topic: Brake pedal sinking to ground ???  (Read 3630 times)
Offline GTi E30
« on: May 21, 2012, 07:25:04 pm »
Hi guys...
I had a rear caliper replaced on my mk5 golf ever since my brake pedal sinks to the floor every time I brake ???
Iv had all 4 calipers bled a good couple of times but the problem is still there  :confused:
Any idea what it could be ???
Cheers...
Re: Brake pedal sinking to ground ???
« Reply #1 on: May 21, 2012, 07:27:21 pm »
Sounds like there is air still in there. Have you checked that your not loosing brake fluid?
Offline GTi E30
« Reply #2 on: May 21, 2012, 10:27:29 pm »
Nah not checked if fluid is leaking... I'll check tomorrow it was fully topped up today after we bled it so il check for any leakage tomorrow
Offline GTi E30
« Reply #3 on: May 23, 2012, 07:14:43 am »
Checked the brake fluid thats still full....
Offline DaveB@Vagbremtechnic
  • Trader - 2014
  • -Receive: 130
    • Vagbremtechnic.com
« Reply #4 on: May 24, 2012, 07:33:45 am »
Hi Pal
It's air.
best bet got to a dealer with a fixed price brake fluid change service and let it be their problem.
Be about £60 normally.
Alternatively remove the caliper from the carrier after tapping it a few times with a rubber mallet and then elevate it in the wheel well with the bleed nipple as high as you can get it and rebleed.
Don't forget to put a wooden block in the caliper if you are up/downing hence you pop the piston our
The VW machine pumps in at a higher pressure at than it sucks it out causing a positive pressure in the system, they also have a device that holds the brake pedal half way down, which avoids problems when pressure bleeding
  • -Receive: 445
« Reply #5 on: May 24, 2012, 07:43:14 am »
mine did the same when i put rear r32 calipers on,bled mine 4 times until it was right--as mentioned it has air still in the system
Offline GTi E30
« Reply #6 on: May 25, 2012, 09:16:18 am »
Thanks guys   :happy2:
Iv got it booked in at a different garage tomorrow this guy is sh*t hot lol lets hoe he can sort it if not then dealers can do it
Thanks...
