Author Topic: Stage 1 Re-Map, should I buy and fit a filter first?  (Read 7348 times)
Offline ianv5
« on: May 22, 2012, 05:21:45 pm »
As above:
Car is a standard 2005 GTi and I am thinking of going for a Stage 1 re-map in the near future probably at R-tech. Is it worth me fitting a Forge Twintake before I get the Re-map or after.
If I just get the Twintake and just run that without the re-map will i notice much improvement in performance?
Offline sub39h
  • -Given: 189
  • -Receive: 84
Re: Stage 1 Re-Map, should I buy and fit a filter first?
« Reply #1 on: May 22, 2012, 05:41:12 pm »
if you're going for a custom remap with R-Tech it would be worthwhile to have the intake fitted first. they'll make sure the map is "prepared" for the better air flow the TwinTake will give the engine.
PLANS: Stage 2+
Offline 56OctyVRS
  • -Receive: 72
« Reply #2 on: May 23, 2012, 11:24:10 pm »
You would benefit more fitting a sports cat downpipe than an intake. The standard air filter will flow up to about 270bhp to 280bhp and a stage 1 map wouldnt be near that. If you fitted a downpipe you could go straight to stage 2 and have about 260bhp and a more driveable car.
Offline ianv5
« Reply #3 on: May 24, 2012, 11:13:23 am »
Recommendation for a sports cat downpipe?
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #4 on: May 24, 2012, 11:39:53 am »
Blueflame are doing a full TBE for £675 delivered on a group buy
call them up and speak to Adam and mention it
PLANS: Stage 2+
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #5 on: May 24, 2012, 11:49:55 am »
turbo back exhaust i.e. an entire exhaust system
it can be a tiny bit boomy under load (nothing the radio at a socially acceptable volume doesn't cover) but is totally silent when cruising
for around half the price of a Milltek i'd say it's 100% worth it
PLANS: Stage 2+
Offline GarethB
« Reply #7 on: May 24, 2012, 12:04:32 pm »
Forge, ITG & Evoms intakes have been proven to give an extra 12-15bhp, even when added post remap - see Robin's review. For me, Stg 1 revo gave me 240bhp on JKM's RR, ITG added at a later date, and then (with no map tweaks) it has & will pull 254bhp on JKM's dyno all day any day.
The noise alone is well worth it  :happy2:
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #8 on: May 24, 2012, 12:17:36 pm »
Gareth you got some great gains there with the ITG  :happy2:
Almost tempting me into getting one  :grin: but i want some exhaust note first!
to answer to OP's question - Definetely worth getting an air filter BEFORE the map to allow the map to be calibrated for the intake.
R-Tech will do you a good map also  :happy2:
« Reply #9 on: May 24, 2012, 12:26:20 pm »
It's as Gareth says. And my review may offer you some additional helpful information:  http://www.mk5golfgti.co.uk/forum/index.php/topic,9988.0.html
....Firstly, Stage 1 is totally "driveable". But perhaps you mean something different than I understand the term 'driveable' to mean.
Secondly, be aware that if, having fitted both high-flow downpipe and air intake and a Stage 2 remap, you will probably find you then need an aftermarket HPFP to avoid cutouts etc. The slippery slope is great fun but starts getting expensive.
Offline gigolo456
« Reply #10 on: May 24, 2012, 12:47:48 pm »
Hi Robin, this is where it goes a bit 'grey'! I mean, i am planning to have a Twintake, then full TBE (BCS), then a custom map (1.5) from R-Tech, hoping that i will get perhaps 260bhp, maybe even a bit more, but i am being told conflicting comments reference the HPFP, you for example are suggesting that it is better to have it, others are stating categorically that it's not required unless you are having a Stage 2+ (R-Tech Stage 2)!? I have a Mk V Golf GTi..
All comments welcome, as most confused now!
Andrew
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #11 on: May 24, 2012, 12:58:03 pm »
my understanding was that it's map dependent
if the map isn't requesting more fuel than the pump can deliver then what's the problem? if you're going for a custom map then the tuner should map the car to within the limits of the hardware, right?
PLANS: Stage 2+
Offline gigolo456
« Reply #12 on: May 24, 2012, 01:01:52 pm »
ahhh, ok, i am hoping then that R-Tech will take into account the fact that i will not have a HPFP and custom the map accordingly!?
« Reply #13 on: May 24, 2012, 01:06:58 pm »
....From what I know of Nick, they most certainly will. You are in good hands with someone who knows the 2.0T FSI engine and not in the predicament like someone else who has posted about their disaster.
Offline ianv5
« Reply #14 on: May 24, 2012, 01:18:23 pm »
Have spoken to the Guys at R Tech and have given me great advice. Thanks Ben :happy2:
Slippery slope is looming but finances will dictate!
Hence will prob go for just the Stage 1 map without filter/downpipe etc first.
Then when I get back from Afghan early next year will spend some of my hard earned on new exhaust, filter, brakes, wheels.............. :laugh:
