Author Topic: Rough prices for straight engine swap or engine rebuild  (Read 18365 times)
Offline Sammy
Re: Rough prices for straight engine swap or engine rebuild
« Reply #15 on: June 06, 2012, 07:16:14 pm »
You cant just swap ecu's as the ecu is coded to the dash.
Use your current ecu and get it mapped for the K04 and S3 injectors.
So are you saying change the map sensor to the S3 one with my current ecu or leaving both my ecu and map sensor as is and getting it mapped?
GTI MK5 with all the gooodies
K04 power going on soon!
Offline vRSAlex
  • -Receive: 253
« Reply #16 on: June 06, 2012, 07:18:34 pm »
So using the origanal gti ecu will work fine, its just the map sensor wont work, which means changing it over for your own engine.
Anything else?
Just the map sensor.  The S3 map reads differently to the stock one.
Depends on the mapper as the S3 map sensor can be mapped to work with the stock ecu.  Easier to just use the stock map sensor and stock ecu.
Follow AKS tuning on Facebook
Offline scopes
  • -Given: 131
  • -Receive: 116
  • Wolfsburg Edition
    • My GTI
« Reply #17 on: June 06, 2012, 07:29:27 pm »
Somewhere someone had mentioned about boosting, they couldnt boost above 21psi.
would there be a problem with this or with the correct tuner could this problem be solved?
quote by James on the Topic: Difference of S3, Cupra and golf R engine
you can also keep your ecu.    but u limit ur boost, 21psi. (what i run)
if you do change your ecu,  change your map sensor also
« Last Edit: June 07, 2012, 12:25:37 am by scopes »
Silver is the way !
Offline scopes
  • -Given: 131
  • -Receive: 116
  • Wolfsburg Edition
    • My GTI
« Reply #18 on: April 27, 2013, 09:57:17 pm »
21 psi = approx. 1.5 bar is this correct ^^^^
What happens when the s3 map sensor is mapped in to the GTI Ecu?
Silver is the way !
Offline edd666999
  • -Receive: 89
« Reply #19 on: April 27, 2013, 09:58:33 pm »
this thread is a year old... :signLOL:
Offline scopes
  • -Given: 131
  • -Receive: 116
  • Wolfsburg Edition
    • My GTI
« Reply #20 on: April 27, 2013, 09:59:46 pm »
Ano... Sammys old thread to... he has gone, but will never be forgotten  :signLOL:
Silver is the way !
Offline Jkingti
  • Ireland Dublin mk5 gti
« Reply #21 on: December 10, 2014, 01:45:52 am »
Hi guys looking for help on this matter. My Axx engine has packed it in so tryin to source an Axx engine is hard
