Author Topic: un retro fitting RNS510 and crusie control  (Read 1632 times)
Offline mad_pete
« on: June 25, 2012, 09:46:08 am »
I'm buying a Pirelli special edtion and want to move across the retro fit cruise and RNS510 from my standard GTI.  Does sat nav and cruise control need to be un programmed in the standard GTI ?  Or will it be okay just to remove the hardware ?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: un retro fitting RNS510 and crusie control
« Reply #1 on: June 25, 2012, 09:37:13 pm »
The cruise will need to be deactivated in the ECU and steering controller
Cluster and Key coding
Location Great Yarmouth
Offline olsen-72
  • -Receive: 21
  • Redditch
« Reply #2 on: July 05, 2012, 09:11:06 pm »
And the same with RNS in Canbus.
STAGING/NEEDLE SWEEP ON ALL WHITE CLOCKS
LIT NEEDLESS, MILES TO EMPTY
GENUINE CAN GATEWAY - SUPPLY AND FIT
CRUISE CONTROL -  SUPPLY AND FIT ALL VW's
CLOCKS CODING - VW SEAT SKODA UP TO 2014
SCIROCCO CLOCKS CONVERSION
Offline Kalpsn2000
  • -Receive: 56
« Reply #3 on: July 12, 2012, 02:18:57 pm »
I'm sure the standard HU will work just fine even if navigation is still activated in the CANBUS. Because mine had the RCD500 in when I bought it and when I fitted the RNS510 later, navigation was already activated (previous owner had his  RNS510 removed prior to sale but not deactivated in the CANBUS).
Although seeing as you will need to deactivate the cruise you may aswell deactivate the navigation at the same time :happy2:
Offline mad_pete
« Reply #4 on: July 13, 2012, 07:22:33 pm »
At this rate cruise might end up staying in so it's good to know the nav will bahave on it's own
