Author Topic: 2 x Questions  (Read 2909 times)
Offline Boothy
2 x Questions
« on: May 27, 2009, 07:02:40 pm »
#1: How much should I be looking at selling a pair of genuine Monza II's that have been restored to factory condition, without rubber?
#2: When I start my car first thing on a morning I can hear a funny noise that sounds like its coming from behind the glove box. To me its like a dull ticking/clicking noise as if its a plastic fan blade catching something as it spins slowly. I've checked the fans at the front of the car and they aren't catching anything plus you can't really hear it if you get under the hood, its just in the cabin? Once its warm it reduces and sometimes stops completely but then on others when I turn the engine off you can hear it slow down until it stops completely. Also if you turn the blowers off completely it gets quieter but doesn't stop it always?
I can only think it could be something to do with either the air-con or the heater/blower fan which I presume is behind the dash somewhere.  :sad1:
Any ideas?
Cheers guys.
Offline NB07
Re: 2 x Questions
« Reply #1 on: May 27, 2009, 07:15:39 pm »
dunno bout the wheels geezer but i had a similar if not the same problem with my car regards to ticking noise was my cam belt so i would get that looked at quickly or it could end up being extremely costly, if its the aircon compressor you dont need to worry asmuch safety wise but if your turning the ignition on with aircon off sounds like it could be what i had. few people said alternater but mine wasnt... check the cold starts thread in technical workshop http://www.mk5golfgti.co.uk/forum/index.php?board=35.0
Offline Boothy
Re: 2 x Questions
« Reply #2 on: May 27, 2009, 07:24:44 pm »
I'll try to look at that. Where is the timing belt? Is it the one on the left side of the engine if your looking at it from the front and could you hear yours under the hood mate?
Offline 182_blue
  • -Receive: 54
Re: 2 x Questions
« Reply #3 on: May 27, 2009, 07:42:12 pm »
as a guide very good condition or new monza 2's should go for about £150 each IMO
Offline NB07
Re: 2 x Questions
« Reply #4 on: May 27, 2009, 08:09:08 pm »
yeh on the left near the front hope you get it sorted  :happy2:
Offline Boothy
Re: 2 x Questions
« Reply #5 on: May 28, 2009, 09:07:53 pm »
Right. It looks like the noise is a combination of two things causing the noise.
One noise is the small fan catching on a metal pipe running behind it. Its only just catching it but its defo coming from there. Not sure what the pipe is but my mechanic friend says it looks like either a power steering or air-con line? Should be able to just persuade it away from the fan.
The second still sounds like its behind the dash. Does anyone know if the blower unit is located there and how it can be got to?
Thanks for the Monza advice too!
Re: 2 x Questions
« Reply #6 on: May 28, 2009, 09:17:47 pm »
The one behind the dash is most likely the Air con. That one has popped up on here loads.  :smiley:
Offline Boothy
Re: 2 x Questions
« Reply #7 on: May 28, 2009, 10:31:14 pm »
How do I get access to the air-con unit and does anyone know if they can be repaired or serviced etc?
