Author Topic: Small job just got bigger  (Read 2118 times)
Offline badbwoy27
« on: July 13, 2012, 11:35:21 am »
Decided to fit h&r springs to golf gti last night with the aid of a friend as thought it wouldn't be to complicated.
All was well until my mate decided to hammer through the abs sensor wire on the front side passenger wheel.  :fighting:
With springs now on have had quite a few lights come up on the car.
Yellow steering light
Abs
ESP
Tyre pressure (stills fitted as monzas being refurb)
Is it just a case of soldiering the wire back together and clearing faults to make my dash not look like a Christmas tree anymore? Will be doing it this afternoon when finish work thanks.
Offline Moz
Re: Small job just got bigger
« Reply #1 on: July 13, 2012, 11:39:10 am »
ABS and ESP will be for the same thing, they both come on together so don't worry.
You can have a go at putting the wires back together, try it, as long as the actual sensor isn't damaged and what not, should be ok to clear.
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 249
« Reply #2 on: July 13, 2012, 02:52:37 pm »
And tyre pressure as that uses the ESP system to detect a flat tyre.
Offline Grande_GTi
  • -Given: 41
« Reply #3 on: July 14, 2012, 09:33:19 am »
If the above fail just take a walk to ur local dealer there only £25 for the loom obviously plus sensor
instgram @ricky_grande
check out @lowlife_official
MK5 GTi OEM+
Offline badbwoy27
« Reply #4 on: July 14, 2012, 05:18:33 pm »
All sorted.connected wires and all lights went out on dash after taking it for a drive.had all faults cleared as well.thanks lads. :happy2:
