Author Topic: Oil level/temp sensor?  (Read 1316 times)
Offline Matto
  • -Receive: 116
« on: July 26, 2012, 08:04:57 am »
Are these a known problem and prone to failure? I keep getting a yellow 'check oil level' warning. It is intermitent and will do it every few days. The oil level is fine as since its been doing it I make sure I check it more regularly. I also have Polar FIS Advanced which displays my oil level and is always reading around 28-30.
Is this likely to be a faulty sensor? I will have a chance to get underneath it next weekend so will check the connection too.
Offline holland15h
Re: Oil level/temp sensor?
« Reply #1 on: July 26, 2012, 08:26:46 am »
I had this problem about a yr ago, got Vw to look at it on a service and possibly replace it if needed, turned out it didn't need replacing, not sure what they did but it's been fine ever since
Offline Matto
  • -Receive: 116
« Reply #2 on: July 27, 2012, 06:34:29 am »
Thanks for the reply.
Anyone shed any light on this? Did it again this morning. Have searched on here previously and came across a few threads but was to do with activating the sensor in the cluster when US clocks had been fitted.
