Author Topic: Top mounts....talk to me!  (Read 5751 times)
Offline vRSAlex
  • -Receive: 253
Re: Top mounts....talk to me!
« Reply #15 on: July 31, 2012, 11:18:15 pm »
Would these ground control mounts fit onto Bilstien b16's or any other aftermarket coilover kit for that matter?
Just Kw iirc, don't fit pss10
Bad Mike!
They do top mounts for any suspension setup which includes the Bilsteins.
I do have them on my car and easily run -3 degs on full adjustment with the TT hubs and wishbones.  Mike's are on their way and I aim to run -2.45 degs on his Leon.
Follow AKS tuning on Facebook
Offline RobH
  • Revo stg 2+
« Reply #16 on: July 31, 2012, 11:32:27 pm »
Bad Mike!
 :signLOL:
Cheers for the info, its deffo something i plan to do when i come round to sorting the bushes and alignment out. Hows the tyres wear and straight line grip with that much camber alex? Front end must feel pretty epic though :driver:
Offline vag12
« Reply #17 on: August 01, 2012, 02:12:23 am »
Loads aftermarket wise.
THS - not overly harsh from what I've read and experienced
BSH - Fairly Harsh so I'm told but no experience of
VWR - Red Robin has these iirc. But they do different types I think Road & Race
VF - I had these in my last car and have a set ready to go on the new one. Not overly harsh and make the car sound like a 6 pot turbo. Slight increase in noise at 70mph but nothing too intrusive. Otherwise you don't notice unless your flooring it.
REVO - Basically re-branded BSH.
Does it change the way the car sounds or just in the cabin to how the driver hears it?
Offline DFish
« Reply #18 on: August 01, 2012, 05:43:23 am »
I take it you dont like the inner tread depth on Mike's tyres then.
Fish
Offline vRSAlex
  • -Receive: 253
« Reply #19 on: August 01, 2012, 07:43:30 am »
Hasn't really affected the straight line grip.  Just improved turn in and cornering grip.  Found its helped loads with wet corning grip.
If you run -3 degs camber and only hit the motorway then the inner edges of the tyres will wear, but if you track or fast road everywhere then the wear is fairly even accross the tyre.
The thing I notice with the standard rubber top mounts is the flex and bounce in them before the damper starts to work.  The solid top mounts allow the coilover to work straight away.
« Reply #20 on: August 01, 2012, 08:35:51 am »
Doh! I was under the impression I couldn't use the PSS10
Take it you have to order specific mounts for each coilover?
Offline DFish
« Reply #21 on: August 01, 2012, 01:50:38 pm »
Looking at the ground control site they do different versions. :)
Fish
Offline RobH
  • Revo stg 2+
« Reply #22 on: August 01, 2012, 01:58:32 pm »
The solid top mounts dont make the ride "crashy" do they? Other than that i think ill do these, probably not -3 degrees, maybe -2 ish :happy2:
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 249
« Reply #23 on: August 01, 2012, 06:46:04 pm »
I bought some OEM equivalent top mounts and bearings from Eurocarparts (or a similar site) for £54 delivered (2 of each).
My H&R springs have killed one of my top mounts I recon.
Gray
