Author Topic: Tips for running in a new turbo?  (Read 991 times)
Offline Moz
« on: August 02, 2012, 05:25:13 pm »
So I've had a new turbo tilted and getting the car back tonight.
Presume I try and avoid hard acceleration and short trips an maybe oil change after few hundred miles?
Offline sub39h
  • -Given: 189
  • -Receive: 84
Re: Tips for running in a new turbo?
« Reply #1 on: August 02, 2012, 05:39:00 pm »
There's a turbo expert on here called Sammy. He's been a bit quiet lately tho.
His advice was to rag it until blue smoke comes out the back. The blue smoke means it's working. The more smoke the better*
(*this is a sarcastic response)
PLANS: Stage 2+
  • -Receive: 453
« Reply #2 on: August 02, 2012, 05:39:42 pm »
Keep the revs down for 200 miles to allow the bearings to bed down.
You shouldn't need to change your oil after a few hundred miles as it should have been a fresh fill with the new turbo assuming you're using a 504 spec oil.
