Author Topic: Stage 3 (k04) APR RR Result  (Read 1990 times)
Offline edd666999
  • -Receive: 89
« on: August 04, 2012, 04:17:50 pm »
K04 turbo
s3 injectors
miltek TBE
ITG
Autotech HPFP
Engine mounts
S3 Cooler
How is that looking to you? Seems optimistic from the 10-15 other graphs i have seen, but the power is just non stop till the red line!  :driver:
Its not without its issues though, already had EML with a misfire on cylinder 4. It hates ME changing up during WOT but if i let the dsg do it its fine.
« Last Edit: August 04, 2012, 05:06:31 pm by edd666999 »
Offline Poverty
  • -Given: 36
  • -Receive: 21
Re: Stage 3 APR RR Result
« Reply #1 on: August 04, 2012, 04:55:39 pm »
graph is upside down!  :signLOL:
Offline edd666999
  • -Receive: 89
« Reply #2 on: August 04, 2012, 04:59:38 pm »
i see...1 moment
Offline Janner_Sy
  • -Receive: 113
« Reply #3 on: August 04, 2012, 05:01:42 pm »
I htought stage 3 was a big turbo  ie SteveP's setup
Offline edd666999
  • -Receive: 89
« Reply #4 on: August 04, 2012, 05:03:10 pm »
i always took stage 3 as different turbo..i.e k04
Offline vag12
« Reply #5 on: August 04, 2012, 05:04:07 pm »
Stage 3 for APR is k04, bigger turbo is stage 4 from APR, I have the same DSG problem as yours when using the flappy paddles
Offline edd666999
  • -Receive: 89
« Reply #6 on: August 04, 2012, 05:05:25 pm »
Offline edd666999
  • -Receive: 89
« Reply #7 on: August 04, 2012, 05:05:56 pm »
What happens to you?
Offline heavyd
  • -Receive: 29
Re: Stage 3 (k04) APR RR Result
« Reply #9 on: August 05, 2012, 12:39:28 pm »
Maf readings don't seem very high  :confused:
I thought they would be around 280g/s for the mods you have?
If you use the old school method of bhp from maf values, it only comes out at 288bhp?
« Last Edit: August 05, 2012, 01:01:00 pm by heavyd »
