Author Topic: Bluetooth..... The dreaded questions!  (Read 4978 times)
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
« on: August 04, 2012, 07:49:51 pm »
Hi all
Im after some bluetooth for my car. I was looking at the "VW Touch" types but it would get on my nerves so looking at the intergrated options. I have:
RNS 510
MFSW
Mid line display (planning on highline soon)
I have been reading round but my head is muddled with all the types. I want to use the RNS-510 / MFSW / Voice control (if able) to control.
What sort of modules should i be looking at? Seen some on ebay with part numbers: 5K0 035 730 D / 7P6 035 730 E / 5N0 035 730 A / 7P6 035 730 F
Any good?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: Bluetooth..... The dreaded questions!
« Reply #1 on: August 04, 2012, 08:19:57 pm »
Hi
I would opt for 5K0 kits, controlled by RNS510
Cluster and Key coding
Location Great Yarmouth
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
« Reply #2 on: August 04, 2012, 08:29:36 pm »
How much are looms? The module im looking at is by itself. Got any in stock Eddie?  :signLOL:
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #3 on: August 04, 2012, 08:53:07 pm »
Hi
I will have some looms and microphones soon
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
« Reply #4 on: August 04, 2012, 09:12:04 pm »
Il be in touch hopefully!
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
« Reply #5 on: August 05, 2012, 01:55:05 pm »
http://www.carsystems.pl/bluetooth-installation-kit-plug-play-for-7p6-and-5k0-module-foam-cover,id126.html
Is this the right loom for a 5k0 D even though it only says its goes upto 5k0 C?
Offline AndyED30
  • ED30
« Reply #6 on: August 05, 2012, 05:44:22 pm »
Hi
Hi Eddie, I've just fitted a RNS510 into my car, it's a version F and I've got a few questions that i cannot find the answers to using the search function. Is it ok to 'pm' them your way? Cheers, Andy.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #7 on: August 05, 2012, 05:58:47 pm »
yes, no problem
Offline hunter2003k
« Reply #8 on: August 09, 2012, 11:23:30 pm »
Hi
Im after a loom for a 5k0 rev d bluetooth unit do you have any yet?
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
« Reply #9 on: August 10, 2012, 08:45:49 pm »
Iv got the bluetooth fitted but now iv got an airbag fault. Its either going to be under the seat or the a-pillar. Going to scan it with vcds to clear it but any other ideas what to check or where the connectors are?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #10 on: August 10, 2012, 08:52:01 pm »
it is probably the seat, have you tried to clear it?
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
« Reply #11 on: August 10, 2012, 09:53:16 pm »
We scanned it and it turned out it was the passenger side which we hadnt touched?! We cleared and its gone so far. Would it throw up an error if you turn the ignition on without the top vent plug, plugged in that shows if the airbag is on / off on the passenger?
Offline olsen-72
  • -Receive: 21
  • Redditch
« Reply #12 on: August 11, 2012, 10:04:38 am »
Yes. If u unplug that it will come as a fault on ur dash
STAGING/NEEDLE SWEEP ON ALL WHITE CLOCKS
LIT NEEDLESS, MILES TO EMPTY
GENUINE CAN GATEWAY - SUPPLY AND FIT
CRUISE CONTROL -  SUPPLY AND FIT ALL VW's
CLOCKS CODING - VW SEAT SKODA UP TO 2014
SCIROCCO CLOCKS CONVERSION
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
« Reply #13 on: August 11, 2012, 01:12:42 pm »
Thanks, put my mind at rest!  :happy2:
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
« Reply #14 on: August 11, 2012, 05:21:46 pm »
2 questions! My phonebook is all backwards, second name then first name. How do i change it?
What is "mobile box" and how do i delete it?! Its pointless!
