Author Topic: Is this wheel spec right?  (Read 1240 times)
Offline Rustybear
  • -Given: 243
« on: August 05, 2012, 09:15:57 pm »
18" 5x112 18x8j et45
Not sure if copy or original so not sure what the above means, hence the question.
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
Re: Is this wheel spec right?
« Reply #1 on: August 05, 2012, 09:18:26 pm »
 What wheels? My CH reps are the above and fit perfectly. Are these monzas?
Offline Rustybear
  • -Given: 243
« Reply #2 on: August 05, 2012, 09:29:21 pm »
Yes sorry 18 monzas. Not worried if reps or original just wanted to know if they would which you have answered thanks!!! :happy2: anything I need to know?
« Reply #3 on: August 05, 2012, 09:31:21 pm »
They are a typical rep offset for reps. ET45
Original 18" monza's are 7.5" wide.
Offline Rustybear
  • -Given: 243
« Reply #4 on: August 05, 2012, 09:34:47 pm »
Great thanks. So should fit on mk5 gti then? As they ar 8 not 7.5 does it make them stick out out? Why are they 8? Sorry first time buying wheels!!! :laugh:
« Reply #5 on: August 05, 2012, 09:38:11 pm »
18 x 8 at ET45 should fit easily as long as you aren't slammed on suspension.
Offline Rustybear
  • -Given: 243
« Reply #6 on: August 05, 2012, 09:41:34 pm »
Great, car is standard so suspension is ok. To the untrained eye they will look just like vw oem then.
« Reply #7 on: August 05, 2012, 09:43:43 pm »
Yes. :happy2:
Offline Nodz
  • -Given: 73
  • -Receive: 103
« Reply #8 on: August 06, 2012, 09:00:00 am »
I originally had 8x18 et45 reps on mine and had no problems. They did seem to fill the arches a bit nicer than the OEM 7.5x18 I've got on now
