Author Topic: G.I. - Possible Airtec FMIC Group Buy  (Read 13591 times)
Re: G.I. - Possible Airtec FMIC Group Buy
« Reply #15 on: August 15, 2012, 12:33:07 am »
The Airtec TWIN SPEC seems a very good option as it saves a significant amount on labour costs compared to the Airtec INTERCOOLER.
Offline kiddfrost
« Reply #16 on: August 15, 2012, 12:42:13 am »
I'm definitely interested but will depend on final price
Offline dan930
  • -Receive: 56
« Reply #17 on: August 15, 2012, 12:59:45 am »
What is the TWIN SPEC??
MK6 golfR dsg
AKS TUNED
NORTECH PERFORMANCE HTA3071
R TECH custom map
Offline Poverty
  • -Given: 36
  • -Receive: 21
« Reply #18 on: August 15, 2012, 01:27:35 am »
forge twintercooler ripoff
Offline edd666999
  • -Receive: 89
« Reply #19 on: August 15, 2012, 02:35:51 am »
Because anyone that makes a intercooler that works along side the OEM intercooler is ripping of an item forge make?  :rolleye:
These items are bar and plate intercoolers and are make to a high standard if the reviews are anything to go by. I have one waiting for me so will post up pictures when i go get it.
Offline Baz300
« Reply #20 on: August 15, 2012, 06:40:17 am »
What is the best one to fit the twin with standard intercooler or replacing the standard one with the one in the first post?
And had anyone successfully fitted the twin model to a mk5?
I assume the twin would be much easier for fitting
Offline edd666999
  • -Receive: 89
« Reply #21 on: August 15, 2012, 06:44:51 am »
according to their website and their tests the front mount one will be better.
The front will be easier fitting.
I believe a few people on here have one fitted, i have one waiting for me at my friends garage, i wont be processing the group buy until i have seen and fitted mine (dont want to push these then find out they dont fit!) I have the S3 cooler too so will be interesting to see if they work along side that cooler.
Offline Poverty
  • -Given: 36
  • -Receive: 21
« Reply #22 on: August 15, 2012, 08:33:00 am »
What I'm saying is that it's a copy of forge's product...
Offline gobbleplease
  • -Given: 64
  • -Receive: 48
« Reply #23 on: August 15, 2012, 09:03:02 am »
Airtech and autospecialist make great products some of the best ive ever bought, i have an airtech on the RS and its great ( won all the cooler group tests ) if i didnt already have an THS i would of been on the gb
MK7 GTI - ARRIVING DECEMBER
« Reply #24 on: August 15, 2012, 09:18:00 am »
....I think I'm right in saying that the term 'FMIC' normally means Front Mounted Intercooler and a front mounted is fitted right up front like a Forge Twintercooler and not like the larger OEM intercooler.
So, are either of Airtec's intercoolers including in this Group Buy or just the one which replaces the OEM?
A front mounted i/c will be significantly cheaper on labour costs and as the Airtec TWIN SPEC (as Airtec call it) is cheaper than the Forge Twintercooler, is it as good or is it better value?
So, will adding a TWIN SPEC to run with an OEM i/c deliver better performance than just replacing the OEM with Airtec's INTERCOOLER? Because if so isn't it a bit of a no-brainer because it's also a cheaper option?
« Reply #25 on: August 15, 2012, 09:22:13 am »
....At the risk of sounding pedantic I think you mean it's a direct equivalent and a competitor of the Forge Twintercooler. But I understood that you didn't mean rip-off in your first post.  :happy2:
« Reply #26 on: August 15, 2012, 09:53:18 am »
I need the big fmic anyway as the plastic end caps on the .:R Probably won't hold up under the higher pressures I'll be wanting.
Hmm, would they do both I wonder?  :laugh:
Offline Dan648v
  • -Given: 28
« Reply #27 on: August 15, 2012, 09:58:59 am »
I have a Airtec twin spec waiting to go on my ed30 and the quality so far is really good!
Am I bothered its not got a forge badge on??!  :booty:
« Reply #28 on: August 15, 2012, 10:04:58 am »
....Rather than be bothered about the brand/badge, isn't it more important to learn which delivers the best performance or whether there are any differences in build quality or design?
Offline edd666999
  • -Receive: 89
« Reply #29 on: August 15, 2012, 10:15:14 am »
I will ask the question for you, if they have the correct hoses for both to be fitted at once.
