Author Topic: Head gasket need replacing on 08 Eddy!! Help please : ( URGENT  (Read 3237 times)
Offline ED30_jase
Re: Head gasket need replacing on 08 Eddy!! Help please : ( URGENT
« Reply #15 on: August 20, 2012, 10:38:13 pm »
Had a similar problem with mine back in may, leaking coolent from the right side of the engine as you look at it, turned out to be a plastic junction that three coolent pipes run-to that then connects to the side of the
engine there's a rubber sealent ring inside that had gone hard like plastic causing the coolent to leak down the side of the engine cost me £75 with the parts, hopefully they've checked this for you ?
I've also been reading about this issue but I don't know if they have checked this? : (
Offline ED30_jase
« Reply #16 on: August 21, 2012, 12:47:36 pm »
Well went in this morning expressed me views and they reduced the bill by 300 bullets so better than a kick in the teeth I guess!
« Reply #17 on: August 21, 2012, 12:54:12 pm »
Result  :smiley:
Offline Statller-Stevo
« Reply #18 on: August 21, 2012, 09:06:10 pm »
Excellent news  :happy2:
