Author Topic: Lowering a Mk5 ED30 with factory Xenons  (Read 1805 times)
Offline B1NCC 1.8T
« on: August 22, 2012, 06:04:09 pm »
Im looking into fitting H&R or Eibach sportline springs to my ED30
I'm wondering what you guys do to overcome the xenon adjusters on the wishbones etc
Or does lowering the car not affect them
I remember seeing a mk5 a while back which was lowered and the xenon adjusters were not working due to the ride height
Any help would be appreciated.
20vt mk2 & GTI Edition30 no 0540
Re: Lowering a Mk5 ED30 with factory Xenons
« Reply #1 on: August 22, 2012, 06:09:22 pm »
I didn't do anything regarding my Xenons (Mk5 GTI) when I lowered (KW V3). I have 95mm road clearance at lowest point under the car.
It has passed MOT at least 3 times since lowered.
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #2 on: August 22, 2012, 06:11:54 pm »
on the 8P they can be recalibrated
PLANS: Stage 2+
Offline Shabba168
« Reply #3 on: August 22, 2012, 10:12:55 pm »
They just need to be readjusted with vagcom after its done
Offline B1NCC 1.8T
« Reply #4 on: August 22, 2012, 10:29:45 pm »
Thanks for the replys guys
I just wondered if the actual adjusters them selves would get damaged/bent once the car is lowered with the wishbone being pushed upwards
Offline JamesG
« Reply #5 on: August 24, 2012, 02:28:19 am »
Keety mines seems fine after i fitted the H&R's more than welcome to have a gander
Pirelli Edition:- APR stage 2+ map,Revo/BSH intake,Autotech hpfp internals,3" downpipe & de-cat,Sachs uprated clutch with smf conversion,H&R springs,race spec superpro polly bushes. 348bhp 360lbft.
Offline higher1
« Reply #6 on: August 24, 2012, 07:11:15 am »
I have factory adjusters and they work fine after fitting eibach springs I now run alot lower on h&r coilovers and they still work fine
Obviously disconnect them before fitting the springs otherwise they will get damaged
Ah-exclusive custom ultra low H&R Coilovers 110mm, ITG induction kit, 18" super RS's, USA rear bumper, USA front grille with smooth number plate surround,recaro bucket seats. now sold !
mk1 golf 1.8 20v turbo
« Reply #7 on: August 24, 2012, 08:13:59 am »
I don't think so.
Offline neg
  • gone old skool
« Reply #8 on: August 24, 2012, 11:06:25 am »
I reset mine using VCDS as they were pointing up - did some kind of reset and they adjusted themselves and were fine from then on.
