Author Topic: Just had the Diagnostic done. RPM Sensor  (Read 2232 times)
Offline Mertyvw
« on: August 29, 2012, 02:19:05 pm »
Hi there i had the ESP light on dash contantly took it to halfords and got it cheked and its the RPM Sensor they say. Whats that gotta do with the ESP, anyone know]?
Black 5 Door TDI with BBS Pescaras, R32 Spoiler, Tints All Round. RCD510,CAN 7NO I aint touching the Engine> Im frightened of power :D
My sig pic is still to big.
Offline Tamiyoman
  • -Receive: 39
Re: Just had the Diagnostic done. RPM Sensor
« Reply #1 on: August 29, 2012, 02:33:21 pm »
I would assume that the ECU needs to know accurate RPM to control ESP, just a guess as I am no spanner monkey  :happy2:
  • -Receive: 453
« Reply #2 on: August 29, 2012, 03:43:34 pm »
A code would have been nice but I suspect one of your esp sensors isn't working. The sensor uses the wheels rate of rotation to work out if if esp braking needs to occur.
Offline PDT
  • -Receive: 142
« Reply #3 on: August 29, 2012, 05:48:57 pm »
Go to a garage that has a clue about what they are doing that can diagnose the fault correctly, provide a detailed explanation and printout as well as a fault code with descriptions of the fault and a quote to replace the requested parts.
Some OBD tools will bring up the RPM sensor as a fault with Bosch ECU systems if the test is carried out without the engine running.
Offline Mertyvw
« Reply #4 on: August 29, 2012, 07:13:31 pm »
Thanks for the advice im thinking of doing that then on my next pay day.
Offline PDT
  • -Receive: 142
« Reply #5 on: August 29, 2012, 07:28:13 pm »
Where are you located? I know a lot of VAG specialists that would help you out.
Offline Mertyvw
« Reply #6 on: September 04, 2012, 06:08:35 am »
Im in wellingborough
Offline Mertyvw
« Reply #7 on: September 04, 2012, 06:08:47 am »
We"@8
Offline vRSAlex
  • -Receive: 253
« Reply #8 on: September 04, 2012, 07:40:56 am »
Short trip down the A6 to Oakley just before Bedford and I can plug it in for you foc.
Follow AKS tuning on Facebook
Offline PDT
  • -Receive: 142
« Reply #9 on: September 04, 2012, 11:15:26 am »
Wont get a better offer than that!
Offline Mertyvw
« Reply #10 on: October 06, 2012, 03:59:55 pm »
Im in london now started back to uni, i think im gna need someone down herre with the vcds vag tool so they can tell me exactly what the problem is.
Offline mad_pete
« Reply #11 on: October 06, 2012, 05:19:31 pm »
At a guess if you know the RPM and the gear ratio you know how fast the wheels should be turning.  Which may be useful to work out if any wheel has traction.
