Author Topic: Low Fuel Rail Pressure, HELP!  (Read 4174 times)
Offline heady2010
Re: Low Fuel Rail Pressure, HELP!
« Reply #15 on: September 03, 2012, 02:17:59 pm »
I currently have a present fault code on my car in relation to fuel level low, do the pressure sensors often fault?
Offline Keith@APR
  • -Receive: 36
    • Go APR
« Reply #16 on: September 03, 2012, 08:05:33 pm »
This is common at stg2 as the extra airflow requires more fuel and the pump can't meet the requested amount. I find that A session on the Dyno and carefull changes to the map should sort you right out.
Only stg2 stuff I don't get this issue with is when a twintake is fitted :stupid:  whenever I am mapping stg2 with evoms or ITG, BSH intakes I eventually hit this issue and have to back off the requested boost and requested load and add a little ignition advance to compensate.
If you need any help I am always at the workshop on 01915239540
Dave.
What's the difference in MAF g/s with the intakes that cause the problem and the one that doesn't?  Just curious.
