Author Topic: DSG, is this normal?  (Read 1763 times)
Offline Black9
  • -Given: 35
« on: October 16, 2012, 10:05:16 am »
My edition 30 is the first auto type box I've owned so I'm new to all of this...
Few things I have noticed are,
When taking off from the lights at a very slow pace with minor throttle input the car can feel a bit jerky but as soon as I apply normal throttle input the car is very smooth and changes gears smoothly too with no jerks.
Car does the same in reverse, feels a bit jerky with small throttle inputs but fine once more throttle is applied. It's more noticeable in reverse.
The mech unit was replaced under warranty back in 2008 and the cars due a DSG service in around 8/9K. Has anyone experienced or heard of 2 mech unit failures? Or Have same symptoms my car has?
Car has REVO stage 1 with VWR suspension parts If that's relavent
Re: DSG, is this normal?
« Reply #1 on: October 16, 2012, 10:27:24 am »
Try a DSG reset with VCDS if anyone has it near you that can help. Then I'd recommend the DSG service straight away to try and cure it. If this doesn't then it could well be the Mech unit again.
Offline Black9
  • -Given: 35
« Reply #2 on: October 16, 2012, 12:16:46 pm »
I was thinking of getting the service ASAP. Would u recommend and a specialist or VW? Both are around the same price! Is there a list of people on here with the VCDS, I'm in Edinburgh.
Does this sound like the typical probs a failed mech unit would cause?
Offline Black9
  • -Given: 35
« Reply #3 on: October 16, 2012, 12:20:43 pm »
And if it poss it a failed mech unit what's the chances of VW replacing it under warranty. It's a 2007 car with 71,000 miles and full VWSH
« Reply #4 on: October 16, 2012, 12:32:52 pm »
IF it does turn out to be the Mech unit, try and get some good will from a VW dealer or VW customer care. Others have in the past.
Try this link for VAGCOM/VCDS users in your area.
http://www.mk5golfgti.co.uk/forum/index.php/topic,120.0.html
It does sound like it could be the Mech unit, but don't hit the panic button yet, you could also try the throttle reset at the same time if you get someone to do the DSG reset for you. :happy2:
Offline Black9
  • -Given: 35
« Reply #5 on: October 16, 2012, 02:18:47 pm »
I'll pm a few members off the list. Hopefully a reset or service should do it. Thanks for your help :)
Offline graeme
« Reply #6 on: October 16, 2012, 02:23:24 pm »
im meeting a freind in glasgow on wed night for some vag com help , probably the closest to you but your best bet would be to try on scottishvag . com and see if any one closer has it  :wink:
Offline Black9
  • -Given: 35
« Reply #7 on: October 16, 2012, 03:21:52 pm »
Unfortunately I'm busy on wed night  :sad1:
I'll register over on Scottish VAG and see if anyone has one closer. Thanks  :smiley:
