Author Topic: Ko4 up grade  (Read 2524 times)
Offline Dv21
Ko4 up grade
« on: October 24, 2012, 08:22:55 pm »
Guys I'm gonna be up grading from ko3 to ko4 very soon I'm buying Donals set up but I have rs4 injectors will this work ok?? And intake and hpfp which ones ?? Also I'm in reading Berkshire where would people recommend I have this fitted and remapped the car currently mapped by shark performance any help would be appreciated
Thanks Daniel
Offline danishmkvgti
  • -Given: 243
  • -Receive: 155
Re: Ko4 up grade
« Reply #1 on: October 24, 2012, 08:36:07 pm »
There's both a Leon twintake and GTI twintake for sale here atm, so depending on what car you could get an excellent intake, read RedRobins review on the twintake to get an idea of what you would get.
Regarding HPFP, there's the Autotech internals for home fitment or get the LOBA rebuilt HPFP for peace of mind IMO
RS4 injectors would be overkill but as long as your tuner has a map for the K04 with RS4 injectors all is fine, but do consider the S3 injectors as the RS4 are for above 400bhp IMO
Over the top mod list ;o)
Offline Dv21
Re: Ko4 up grade
« Reply #2 on: October 24, 2012, 08:44:37 pm »
Thanks for that it is a gti which I forgot to add I may have to put these rs4 injectors up for sale once again thanks for info  :happy2:
Offline sub39h
  • -Given: 189
  • -Receive: 84
Re: Ko4 up grade
« Reply #3 on: October 24, 2012, 11:50:08 pm »
is there really an improvement with RS4 injectors? i read somewhere that they flow the same amount of fuel as the regular K03 injectors, which would make sense as each cylinder is only producing about the same amount of power as each cylinder in the K03 engine 2.0T (197bhp/4cyl = 49ish, 414bhp/8cyl = 52ish)
PLANS: Stage 2+
  • -Receive: 453
Re: Ko4 up grade
« Reply #4 on: October 25, 2012, 09:57:23 am »
Problem with the rs4 injectors is that don't give an ideal spray pattern for the gti engine vs the S3 ones.
Offline Dv21
Re: Ko4 up grade
« Reply #5 on: October 25, 2012, 10:30:03 am »
CHEERS BACILLUS I GUESS ILL BE PUTTING THEM ON EBAY THEN  :happy2:
Offline Evan@APR
Re: Ko4 up grade
« Reply #6 on: October 25, 2012, 08:27:12 pm »
Hey DV21
Consider that most remappers account for the S3 injectors instead of the RS4 options as you have previously discussed unless you're going for a completely custom map. And then again the spray pattern isn't optimal for this head. APR offers a K04 remap for your vehicle and I'd advise you upgrade to an RS4 fuel pressure relief valve to get the maximum from your vehicle with the HPFP and injectors.
Details about the kit and remap can be found here: http://www.goapr.co.uk/products/turbo_trans20t_k04.html Please note, the remap can be purchased separately of the kit (£499+VAT) and will function as advertised if the components match.
If you are considering the APR remap avenue, we have two distributors you seem to sit conveniently between.
Gwent VW Audi Centre
Unit 19-20 Estuary Road
Queensway Meadows, Newport NP19 4SP
01633 281 222
gwentvw.co.uk
And
Tuningwerkes
40 Haling Road
South Croydon CR2 6HS
020 8681 0208
tuningwerkes.com
While you're at it, may I recommend you check out our fuel pump? Fully rebuilt, tested and comes with a lifetime warranty! :)
http://www.goapr.co.uk/products/fsi_fuel_pump.html
If you have any additional questions, please don't hesitate to reach out.
GO APR!
APR UK
www.goapr.co.uk | elight@goapr.com | 0845 680 3527
“The bitterness of poor quality remains long after the sweetness of low price is forgotten”
Re: Ko4 up grade
« Reply #7 on: October 25, 2012, 08:48:15 pm »
You could go to JKM as they have several successfully converted K04 cars already running.  :happy2:
Offline james
Re: Ko4 up grade
« Reply #8 on: October 26, 2012, 08:08:50 pm »
cheaper to take your engine out and put a full s3 engine and sell your old engine
i worked that out the hard way  lol.
Offline JMP
Re: Ko4 up grade
« Reply #9 on: October 27, 2012, 09:41:54 am »
By the way, do you know what are the changes needed in the car to make this happen (in detail)? And what software should be used, is the change tailored around S3 or GTI sw? IIRC boost sensor range is different between the engines.
