Author Topic: Number plate LEDS (again)  (Read 3206 times)
« on: October 30, 2012, 08:26:51 pm »
The ebay links in the previous posts I had a look at don't work any more (outdated). I know festoon ones are popular and I had them for a year but I've had one fail already.
Am looking at these:
clicky
18 SMDs in a complete unit. Has anyone bought these at all?
Offline suave
  • -Given: 31
Re: Number plate LEDS (again)
« Reply #1 on: October 30, 2012, 09:25:07 pm »
SW
I got some canbus  ones from a guy on here after my last ones started to fail and flash. Could PM you his email from office tomorrow if you want - they were only a few quid.
These ones of yours look good mind you
Offline f1fan
« Reply #2 on: October 30, 2012, 10:24:37 pm »
clicky
How much????!
I've just bought these http://www.ebay.co.uk/itm/120969999034
Black 2008 GTi, InPro smoked door mirror indicators, genuine Autohaus Wolfsburg plate holders, uk legal pressed metal plates, LED number plate lights, MTEC super white headlights & side lights, LED internal lights, Polo stubby aerial, Kenwood DDX4023BT head unit & Enfig surround.
Offline Ree
« Reply #3 on: October 31, 2012, 01:41:45 pm »
i fitted the 18 led units to my car, They are very bright,
I took these pics when it was still dusk so not getting the full effect from the pics, But gives you the idea.
one side done and one side standard.
I have these no issues at all !
Previously had ones from the rocco these gave errors and often needed to restart the engine or turn lights off and on again to get them restarting.
« Reply #4 on: October 31, 2012, 02:04:05 pm »
From your pics, Cap, I gather they're just push-fit?
Offline CAPTAIN BRITAIN
« Reply #5 on: October 31, 2012, 03:51:44 pm »
That's right,
Just unscrew the old ones and disconnect the cable, reattach the cable to the new unit and pop back in.
The little silver boxes that you see in the pic are the resistors, I didn't use them and have no problems whatsoever
Offline Mertyvw
« Reply #6 on: October 31, 2012, 09:20:06 pm »
I wanted them aswell but not really sure how to fit them on
Black 5 Door TDI with BBS Pescaras, R32 Spoiler, Tints All Round. RCD510,CAN 7NO I aint touching the Engine> Im frightened of power :D
My sig pic is still to big.
« Reply #7 on: November 05, 2012, 02:24:02 pm »
Well mine arrived today and I just fitted them. Fairly simple but the connections don't "click" firmly into place. They also don't fit perfectly into the socket - I think a rubber shroud would have helped.
Otherwise in terms of illumination, far brighter than the festoon ones.
Offline Timi8888
« Reply #8 on: November 05, 2012, 02:46:12 pm »
If you were to get the cheap ones off ebay do they tend to blow quite easily then?
Sig to big.
Offline TANNER
« Reply #9 on: November 05, 2012, 10:39:41 pm »
The eBay ones I've used the past year or so from seller fizzmo have lasted about 4 months a time before the flickering started. Great quick delivery and look good but getting a bit bored of replacing them 3 times a year! Be interested to see how these 18 LEDs hold up. Do they look like floodlights at night though? I see an s3 locally and it's like he has 2 maglites on his plate from afar!
Offline Timi8888
« Reply #10 on: November 06, 2012, 12:24:01 pm »
Ah yeah I have had the cheap ones off ebay for a couple weeks now. Hopefully they last as long as possible, if they do go quickly I will be buying more expensive ones!
Sig to big.
« Reply #11 on: June 14, 2013, 02:45:03 pm »
Right, to update,
The 18 smd ones above have failed after 8 months of use. That's worse than the festoon type which used the car's OEM holders and just swapped SMDs for bulbs. The 18-SMD ones didn't seem to fit snugly and show signs of corrosion within the unit but the unit and the connections are fine.
Any different ones to recommend?
Offline trs888
  • -Given: 17
  • -Receive: 20
« Reply #12 on: June 14, 2013, 11:02:23 pm »
Right, to update,
same happened to me. but to be fair ive just bought the same from a different place. i prefer the 18 SMD ones to festoon bulbs.
Offline david25
  • -Given: 19
« Reply #13 on: June 15, 2013, 11:06:45 am »
Official ones from the MK6 are nice BUT expensive;
http://www.mk5golfgti.co.uk/forum/index.php/topic,30092.0.html
