Author Topic: P0087 fault code fuel system rail pressure  (Read 3217 times)
Offline vag12
« on: November 03, 2012, 01:17:43 am »
As above I keep getting this code, what can it suggest?
It says fuel rail system pressure too low
  • -Receive: 453
Re: P0087 fault code fuel system rail pressure
« Reply #1 on: November 03, 2012, 11:33:41 am »
Checked your cam follower?
Offline john a
    • The Veneers Cover Band
« Reply #2 on: November 03, 2012, 12:17:52 pm »
I'm also having this problem intermittently, I've replaced my cam follower and still the same issue.
Offline vag12
« Reply #3 on: November 03, 2012, 12:39:08 pm »
I havnt checked my cam follower just yet, I take it the sensor can be at fault too?
  • -Receive: 453
« Reply #4 on: November 03, 2012, 02:47:01 pm »
Yes, the low fuel pressure sensor that screwed into the hpfp can also bring up this fault but visually check your cam follower first.
Offline vag12
« Reply #5 on: January 19, 2013, 07:13:36 pm »
I have changed this bacillus but fault still reappears? Anything else?
Offline vag12
« Reply #6 on: January 19, 2013, 07:14:19 pm »
Have you sorted yours yet mate?
Offline john a
« Reply #7 on: January 19, 2013, 09:40:46 pm »
My car now has Autotech internals but I've not done any logs or ran an autoscan since they were fitted.
