Author Topic: Remove exhaust cutout on R32 rear bumper  (Read 2459 times)
Offline Kalpsn2000
  • -Receive: 56
« on: November 11, 2012, 11:17:17 am »
I need a tip regarding the title. I have unclipped the lower clips but just cannot do the top ones :ashamed:
Is it just a case of pulling hard? Don't want to great it.
Want to swap over today so any quick tip will be greatly appreciated.
Offline StephenED30
  • -Receive: 53
  • Edition 40 No 135
Re: Remove exhaust cutout on R32 rear bumper
« Reply #1 on: November 11, 2012, 11:44:07 am »
Easier to take the complete assembly off the car, if you have got a problem getting it off thing of how you are going to refit it.
Fitting guide here.  :happy2:
http://forums.vwvortex.com/showthread.php?3754634
Offline Kalpsn2000
  • -Receive: 56
« Reply #2 on: November 11, 2012, 12:01:30 pm »
I am having an issue removing just the exhaust cutout. The bumper is off the car. The top row of clips are tough to remove.
Offline Nodz
  • -Given: 73
  • -Receive: 103
« Reply #3 on: November 11, 2012, 12:20:24 pm »
I had grief with mine, the exhaust heat shield is blocking a few of the clips so that needs to come off. I worked from one end used a screw driver to lever the clips out. PITA job but it does come out eventually
Offline Kalpsn2000
  • -Receive: 56
« Reply #4 on: November 11, 2012, 12:24:26 pm »
Ah thought that might be the issue as have managed to get the edge clips out but the centre is stuck :fighting:
Offline Nodz
  • -Given: 73
  • -Receive: 103
« Reply #5 on: November 11, 2012, 12:27:08 pm »
On mine the clips for the heat shield had melted so broke the clips so mine hasn't got a heat shield on it but I haven't had any issues
Offline Kalpsn2000
  • -Receive: 56
« Reply #6 on: November 11, 2012, 12:38:50 pm »
Yes my heat shield clips have melted also. I took two of them off and managed to reach the other cutout clips without removing the heat shield fully.
Thanks mate :happy2:
Offline Kalpsn2000
  • -Receive: 56
« Reply #7 on: November 11, 2012, 06:37:54 pm »
Finished changing the bumpers over but have a slight issue now. While removing the licence plate light/parking sensor connector (the main connector on the rear drivers side) I snapped the clip. So when putting it back in I used duct tape to hold it together and it looked fine. But after finishing I turned the ignition on and it came up with the light out warning and the licence plate light/rear parking sensors don't work, just get a long beep then nothing.
I can feel,the connector is still connected as I can reach under the bumper but I assume its not tight enough.
So is it an easy fix or not?
P.S. Really like the bumper and new lights but this has put a downer on the change :sad1:
