Author Topic: Polar fis has f***ed my car (more faults now)  (Read 26712 times)
Offline bakili
Re: Polar fis has f***ed my car
« Reply #15 on: November 27, 2012, 08:47:58 pm »
Do I need disconnect battery when unplugging canbus?
Offline Baz300
« Reply #16 on: November 27, 2012, 08:48:52 pm »
I think it's best to
I just disconnected the negative terminal
Offline Mandy
  • -Given: 95
  • -Receive: 94
« Reply #17 on: November 27, 2012, 09:49:28 pm »
Why don't you see if anybody near you has VCDS, I'm sure someone will be happy to help. :happy2:
http://www.mk5golfgti.co.uk/forum/index.php/topic,120.0.html
Offline Baz300
« Reply #18 on: November 27, 2012, 09:51:44 pm »
Ess-three is the closest to me but still a bit of a distance to travel
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #19 on: November 27, 2012, 09:53:30 pm »
I know some K version gateways had issues with polar FIS
Cluster and Key coding
Location Great Yarmouth
Offline Baz300
« Reply #20 on: November 27, 2012, 09:56:05 pm »
I have a 7NO gateway is that the same as K?
Is it worth me trying the original  gateway?
Offline Baz300
« Reply #21 on: November 27, 2012, 10:08:46 pm »
Polar have asked me to try and update the firmwear again so will give that a try tomorrow (good job I put the unit in the cubby hole under the steering wheel)
I was planning on buying VCDS next year but If I cannot get the airbag fault cleared then I will have to get this sooner as my MOT is due in January
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #22 on: November 27, 2012, 10:17:41 pm »
the problem is with the polar, some versions have stability issues
  • -Receive: 453
« Reply #23 on: November 27, 2012, 10:31:20 pm »
Ed according to polar, the last beta firmware and the latest 3.0 one have sorted that issue with the 7NO gateways.
Offline RoMocop
« Reply #24 on: November 27, 2012, 10:35:12 pm »
I'm starting to get a little worried now as I also have the 7N0 gateway. :scared:
Offline Baz300
« Reply #25 on: November 27, 2012, 10:39:51 pm »
Did you get yours fitted today?
Offline RoMocop
« Reply #26 on: November 27, 2012, 10:44:09 pm »
No, not quite. I gave up and was going to carry on with it tomorrow. Was there a reason why you updated the firmware yourself as I was told they came with the newest version anyway?
Offline Baz300
« Reply #27 on: November 27, 2012, 10:47:45 pm »
There was a post on here saying that a new firmware had been released after my one was posted so I just assumed it would of been a newer version
  • -Receive: 453
« Reply #28 on: November 27, 2012, 10:54:40 pm »
I installed a 7NO gateway in September as I was getting the rns510 but my polar with firmware version 0.2.7 didn't like it as the radio and nav disappeared when scanned with vcds. Without the polar connected everything was fine.
After getting alot of support from polar including a then bespoke firmware that only partially helped, I resorted to reinstalling my old "non RNS510 compatible" F gateway. Everything works fine with no battery drain. The only silent issue I have is a non urgent error in vcds for the nav which works faultlessly. I may try the 7NO gateway in the future but at this time I see no urgent need to change even with the latest firmware supporting 7NO gateways.
1 Fault Found:
01299 - Diagnostic Interface for Data Bus (J533)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 224
                    Mileage: 38265 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:42:21
« Last Edit: November 27, 2012, 10:56:51 pm by bacillus »
« Reply #29 on: November 27, 2012, 10:59:05 pm »
Sounds like it can be glitchy.
My ultimate solution would be the Facelift / 2009 large display Cupra R clocks (white backlit) to replace my small screen 2008 Cupra clocks. Then add the polar.
I don't know where to start with the retrofit though or if it's even possible. I imagine it's like upgrading a mkV to the Mk6 colour screen or similar.
