Author Topic: Polar fis has f***ed my car (more faults now)  (Read 26775 times)
  • -Receive: 453
Re: Polar fis has f***ed my car
« Reply #30 on: November 27, 2012, 11:02:50 pm »
There was a post on here saying that a new firmware had been released after my one was posted so I just assumed it would of been a newer version
I suspect I was the author of that post and it was for the latest version 3.0 firmware.
Quote
Was there a reason why you updated the firmware yourself as I was told they came with the newest version anyway?
They should do but as there are two versions of the latest firmware (red_dot and white_dot) it's prudent to flash the unit again before installation with the known correct firmware.
« Last Edit: November 27, 2012, 11:16:16 pm by bacillus »
Offline bakili
« Reply #31 on: November 27, 2012, 11:07:41 pm »
I have 1K0 907 530 L gateway and basic polar FIS (not sure what firmware), am I safe to install?
  • -Receive: 453
« Reply #32 on: November 27, 2012, 11:13:05 pm »
Yes! L and above gateways should have no battery drain issues.
The Polar FIS is no longer officially supported but I would update it's firmware to the latest v1.6.0 for stability reasons if running an earlier firmware version.
« Last Edit: November 27, 2012, 11:17:26 pm by bacillus »
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #33 on: November 27, 2012, 11:18:40 pm »
I'm starting to get a little worried now as I also have the 7N0 gateway. :scared:
I installed a 7NO gateway in September as I was getting the rns510 but my polar with firmware version 0.2.7 didn't like it as the radio and nav disappeared when scanned with vcds. Without the polar connected everything was fine.
After getting alot of support from polar including a then bespoke firmware that only partially helped, I resorted to reinstalling my old "non RNS510 compatible" F gateway. Everything works fine with no battery drain. The only silent issue I have is a non urgent error in vcds for the nav which works faultlessly. I may try the 7NO gateway in the future but at this time I see no urgent need to change even with the latest firmware supporting 7NO gateways.
1 Fault Found:
01299 - Diagnostic Interface for Data Bus (J533)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 224
                    Mileage: 38265 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:42:21
I had to send another gateway due to the issue with the polar
Cluster and Key coding
Location Great Yarmouth
Offline bakili
Re: Re: Re: Polar fis has f***ed my car
« Reply #34 on: November 27, 2012, 11:23:03 pm »
Sent from my GT-I9100 using Tapatalk 2
Mandy or Romocop might be able to tell me what firmware i have on my polar fis. ;)
Offline RoMocop
« Reply #35 on: November 28, 2012, 12:22:20 am »
We're not sure, it was purchased from a member on here. We didnt have it long and never had a chance to fit it. I wonder if theres a way to tell if you connect it to a computer.
Offline RoMocop
« Reply #36 on: November 28, 2012, 12:23:20 am »
Baz- did you get an instruction manual or CD or anything with yours?
Offline Baz300
« Reply #37 on: November 28, 2012, 06:45:48 am »
I didn't get anything just the black box. Loom and USB cable
Offline Matto
  • -Receive: 116
« Reply #38 on: November 28, 2012, 09:40:50 am »
Once its connected to the Polar update service it will tell you what firmware version it has installed  :happy2:
Offline Baz300
« Reply #39 on: November 28, 2012, 05:58:22 pm »
I reupdated the firmware as per polars request tonight then tried the unit in the car
Has made no difference at all, still no audio or polar menus and I still have the airbag warning
Offline Baz300
« Reply #40 on: December 01, 2012, 12:53:01 pm »
I swapped over can gateways today to the original one from the car and it made no difference at all
Put the 7no gateway back in and I got a steering wheel icon in the rev counter and the car would not start (ran for a second then cut out)
I have totally removed the polar unit and the car runs now but I still have the airbag fault, steering wheel icon and have lost the audio menu on the MFD
I have orderd a VCDS cable from gendan will I be able to get the audio menu back?
  • -Receive: 453
« Reply #41 on: December 01, 2012, 01:15:08 pm »
I assume you disconnected your battery again then got the steering wheel light. If yes, turn the car on, turn the steering fully to the left and hold for a few seconds then turn fully to right, hold for a few seconds after that straighten/center the steering wheel and drive slowly for a few metres dead straight. the light should extinguish itself.
Does your head unit actually work and output sound? I can only postulate that somehow your radio/nav unit isn't being detected by the canbus hence no audio menu. A vcds scan will show if this is the case.
I'm beginning to wonder if there is a hardware issue with these new black polar units as the new firmware works a treat with the old silver version. Two members with the same issue seems more than coincidence...
Offline Baz300
Re: Polar fis has f***ed my car (more faults now)
« Reply #42 on: December 01, 2012, 01:18:26 pm »
I will try the steering when I'm out later
The stereo works perfect an the MFSW volume buttons still work
Offline Baz300
« Reply #43 on: December 03, 2012, 01:01:13 pm »
Fault codes galore
VCDS Version: Release 11.11.4 (x64)
Data version: 20120807
Monday,03,December,2012,12:42:54:37886
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 75 77
VIN: WVWZZZ1KZ6W091997   Mileage: 75430km/46870miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 1010
75-Telematics -- Status: Not registered 0001
77-Telephone -- Status: Not registered 0011
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1K0 907 115 J    HW: 1K0 907 115 F
   Component: 2.0l R4/4V TFSI     0030
   Revision: --H10---    Serial number: VWZ7Z0E2969947
   Coding: 0403000318070060
   Shop #: WSC 66565 257 00032
   VCID: 2D51CE52B482C070BA3
1 Fault Found:
008852 - Fuel Pressure Regulator Valve (N276)
               P2294 - 004 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 75416 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 12:35:24
             Freeze Frame:
                    RPM: 764 /min
                    Load: 21.2 %
                    Speed: 0.0 km/h
                    Temperature: 40.0°C
                    Temperature: 2.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 14.097 V
Readiness: 0000 0101
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 AA    HW: 1K0 907 379 AA
   Component: ESP FRONT MK60      0102
   Revision: 00H13001
   Coding: 0004738
   Shop #: WSC 01279 785 00200
   VCID: 71E91222683AE490DEB
4 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
            004 - No Signal/Communication - Intermittent
00474 - Control Module for Immobilizer
01312 - Powertrain Data Bus
            014 - Defective - Intermittent
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1K0 907 044 BE
   Component: ClimatronicPQ35 090 0808
   Shop #: WSC 00000 000 00000
   VCID: 6BD5004A4A160E40E47
4 Faults Found:
01316 - ABS Control Module
01314 - Engine Control Module
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000005174093
   Coding: E58D8F2700041800001400001400000000087F075C
   Shop #: WSC 00000 785 00200
   VCID: 2B55C04A8A96CE40A47
   Subsystem 1 - Part No: 1K2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  013  0402
   Coding: 00065493
   Shop #: WSC 00000
   Subsystem 2 - Part No: 1K0 955 559 T  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 011  1110
   Coding: 00207646
   Shop #: WSC 00000
3 Faults Found:
00906 - Horn (H1)
            009 - Open or Short to Ground - Intermittent
             Freeze Frame:
                    Fault Status: 00101001
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 6
                    Mileage: 75416 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 14.05 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
02071 - Local Databus
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 6
                    Mileage: 75416 km
                    Time Indication: 0
             Freeze Frame:
                        OFF
                    Voltage: 12.40 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
00153 - Windshield Wiper Motor;  Driver Side (V216)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 16
                    Reset counter: 6
                    Mileage: 75416 km
                    Time Indication: 0
             Freeze Frame:
                        OFF
                    Voltage: 12.40 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 R    HW: 1K0 909 605 R
   Component: 38 AIRBAG VW8   018 2200
   Revision: 02018000    Serial number: 0038MD02XAKP
   Coding: 0013112
   Shop #: WSC 01269 785 00200
   VCID: 3B75F00A7AF65EC0347
2 Faults Found:
            014 - Defective - Intermittent - MIL ON
            004 - No Signal/Communication - Intermittent - MIL ON
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AG    HW: 1K0 953 549 AG
   Component: J0527           634 0070
   Coding: 0002002
   VCID: 77FD2C3A065EBAA010F
   Part No: XXXXXXXXXXX
   Component: E0221           007 0050
1 Fault Found:
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1K6 920 972 D
   Component: KOMBIINSTRUMENT VDD 4312
   Coding: 0003403
   Shop #: WSC 00835 210 105516
   VCID: 3365D82A52A69680EC7
5 Faults Found:
01309 - Power Steering Control Module (J500)
01321 - Control Module for Airbags (J234)
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 2800105B140134
   Coding: 3D0F0340070001
   VCID: 2A5BC54E856CD7485F1
3 Faults Found:
01044 - Control Module Incorrectly Coded
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 1
                    Fault Frequency: 6
                    Reset counter: 221
                    Mileage: 75372 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:30:06
01305 - Databus for Infotainment
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 2
                    Reset counter: 5
                    Mileage: 75416 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 12:31:14
01304 - Radio
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 7
                    Reset counter: 5
                    Mileage: 75416 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 12:31:15
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 4312
No fault code found.
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX2.lbl
   Part No: 1K0 959 701 L
   Component: Tuer-SG         024 2484
   Coding: 0000566
   VCID: 377DEC3A46DE7AA0D0F
2 Faults Found:
00932 - Electric Window Motor; Drivers Side (V147)
            005 - No or Incorrect Basic Setting / Adaptation - Intermittent
00941 - Exterior Mirror Retract Motor; Driver Side (V121)
            012 - Electrical Fault in Circuit - Intermittent
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 K
   Component: EPS_ZFLS Kl.5   D06 1701
   VCID: 3467DB3657A891B8F5D
1 Fault Found:
             Freeze Frame:
                    Mileage: 0 km
                    Temperature: 9.0°C
                    Voltage: 11.90 V
                    Voltage: 11.70 V
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 AQ    HW: 1K0 959 433 AQ
   Component: 02 KSG PQ35 G2  010 0101
   Revision: 00010000    Serial number: 00000000000000
   Coding: 819002085103087F2D04840570085AC690A440
   VCID: 7F0DC41A2E6E82E058F
   Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H03 1301
   Part No: 1K0 907 719 C
   Component: Neigungssensor  005 0003
   Part No: 1K0 951 177 A
   Component: Innenraumueberw.005 0202
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 6
                    Reset counter: 6
                    Mileage: 0 km
                    Time Indication: 0
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX2.lbl
   Part No: 1K0 959 702 L
   Coding: 0000566
   VCID: 387FEF064BC075D8D95
2 Faults Found:
00933 - Electric Window Motor; Passenger Side (V148)
00942 - Exterior Mirror Retract Motor; Passenger Side (V122)
Address 56: Radio (J0503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 3C8 035 195 A    HW: 3C8 035 195 A
   Component: Radio RCD510  040 0144
   Revision: 00000001    Serial number: VWZ1Z3I5292946
   Coding: 0100040004
   Shop #: WSC 00020 790 00000
   VCID: 2643317E5174F3287B9
4 Faults Found:
00849 - S-contact at Ignition/Starter Switch (D)
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 4
                    Reset counter: 6
                    Mileage: 1048575 km
                    Time Indication: 0
00625 - Vehicle Speed Signal
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 191
                    Mileage: 75225 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:19:10
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 5
                    Reset counter: 188
                    Mileage: 1048575 km
                    Time Indication: 0
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 5
                    Reset counter: 6
                    Mileage: 1048575 km
                    Time Indication: 0
Address 75: Telematics
Cannot be reached
Address 77: Telephone
Cannot be reached
End   ---------------------------------------------------------------------
polar are sending me out a new unit
  • -Receive: 453
« Reply #44 on: December 03, 2012, 01:10:42 pm »
I would try clearing all the faults and rescan as you get loads of errors when you disconnect the gateway.
Also I see that you've put your old gateway back in. Do you actually have a telefone kit installed?
