Author Topic: 30-130 day at RAF Marham 24th March  (Read 67135 times)
Offline mechell
« on: December 28, 2012, 10:24:25 am »
Thanks as always to RAF Marham, I’m very pleased to confirm the MLR's 30-130 event will be held on Sunday 24th March 2013 all-marque’ day.
“30-130” is the best opportunity for you to understand the REAL performance of your Evo! This isn't a standing start, but a rolling start from below 30mph after which you have approx 1.5miles of straight ultra smooth tarmac to pass 130mph - or carry on for a top speed run.
There's no running order so you can run when you want (subject to the queue - which we get through as quickly as possible!) The average number of timed runs is approx 5 or 6, but we've seen some drivers do 15+ runs.  You’re welcome to do a run without a VBox (or use your own if you have one) to bypass the queue and go straight out, but only data from the MLR's calibrated VBoxes being used on the day will be used in the results.
The current 30-130 record is still held by RossW in his Evo6 in a time of 5.84s.
Please read ALL the following information carefully, paying particular attention to the Registration & Security Clearance requirements below;
NEW ONLINE REGISTRATION & SECURITY CLEARANCE
ALL DRIVERS & SPECTATORS MUST HAVE SECURITY CLEARANCE BEFORE BEING ALLOWED ON SITE.
To ensure we don’t have a reoccurrence of the 2012 entry problems, there will be a new online form for 2013 that all drivers must complete for themselves and their passengers (maximum of 4 passengers per driver).
  • This form will only be available after you have booked your place
  • All drivers need to be registered on the MLR forum as the online form will be linked to the forum. This can be done here: http://www.lancerregister.com/register.php
  • Additional drivers should be registered as a passenger
Entries will be available via the MLR (Tel: 08451 25 26 23) and http://www.lancerregister.com/store_category.php?id=13   MLR Shop from Monday 7th January 2013
Online registration forms will also be available from 7th January, and all forms need to be completed by 28th February 2013
Everyone - without exception - needs to complete a Registration Form details regardless of whether you have been security cleared for previous events, have clearance to work on this station, or are serving RAF personnel etc.   If you miss the deadline and do not register you will not be able to attend as you will not receive security clearance.
30-130 EVENT:
  • We’ll use the full length of the 1.5 mile / 60m wide runway of super smooth tarmac
  • All cars will be fitted with a Racelogic V-Box in front of the MLR unit to record your car's performance
  • Cars will run one at a time and must start each run within the designated area for that run to count
  • After completing a “30-130 run” drivers have the option to complete a top speed run if they wish. This is not compulsory but you may not have a better, safer and legal way to find out your car’s top speed
  • The next car will be released when the previous car has passed the halfway mark on the runway
  • You must brake at the braking markers to ensure you don’t overrun the end of the runway and risk damaging the airfield infrastructure
  • Once the car has returned to the Paddock and the VBox has been removed, your 30-130 time and Top Speed result (if applicable) will be displayed at the MLR unit as soon as Dave has downloaded the data from your run
EVENT TIMETABLE:
  • 07:30 - Gates open. (DO NOT stop at the Guardroom - go straight through to the first barrier checkpoint. You MUST show your Photo ID on the day or you’ll be turned away)
  • 07:45 - Driver and Passenger Registration / Car number and wristband collection
  • 08:30 - Drivers briefing (mandatory)
  • 09:00 – Sighting lap
  • 09:30 – Event start
  • 12:30 – Lunch break
  • 13:00 – Event restart
  • 16:00 – Event close
HOW TO BOOK:
Places can be booked from 7th January 2013 via the MLR Shop, or by calling Mechell direct on 08451 25 26 23
  • Car and driver: £99
  • Additional drivers: £59 (pay on the day)
  • Passengers: £10 (pay on the day)
Note:  Bookings close on 28th February 2013
ADDITIONAL INFO:
Drivers:
All drivers must have full UK driving licence
Photo ID:
ALL drivers and passengers must bring photographic ID on the day to be allowed into the venue (no photographic ID = no entry)
Fire Extinguishers:
ALL cars must have a fire extinguisher fitted - preferably in an easy to reach place, eg: in front of the passenger seat. This will be checked on the day and any cars without extinguishers will not be allowed to run
Corner Weights:
We will have our corner weights at the event as usual, so if you want to corner weigh your car you can do so anytime during the day. This will be managed the service and direct you onto the ramps and the scales. Readings will be recorded and can be taken with and without the driver
Helmets:
Helmets must be worn by all occupants - drivers and front seat passengers
Noise Limit:
Noise from motorsport has now become an issue for RAF Marham. Although it’s understood that running a single car at 30-130 is not the same as running numerous cars together at a trackday, noise monitoring will take place on the day if required but they will be as lenient as possible. We are not allowed unsilenced exhaust systems. The static noise limit is 105dBA (measured at ½ metre, 45 deg, ¾ revs)
Rear Spoilers:
For reasons of safety, cars must retain their rear spoilers and blade, unless fitted with a carbon bootlid or similar which does not allow for a rear spoiler
Vortex Generators and Trim:
Debris of ANY type on the runway is the single biggest concern at RAF Marham. Aftermarket VGs and other trim have a tendency to come off when travelling at over 130mph, so all VGs will need to be taped front and back to ensure they stay on the car. If it’s not done when you come to collect your VBox we will do it for you!
Towing Eyes:
It is your responsibility to have a towing eye or strap fitted and/or accessible on the day in case you need to be recovered. The RAF recovery crew are experienced and will treat your car like their own, but they have to be able to return your car to the paddock, so please make their life as easy as possible whilst also removing the risk of damage to your car
Passengers:
Only front seat passengers are allowed and must be 16 years old or over. There is a small charge of £10 for passengers on the day
Refreshments:
Food & drink (burgers, bacon rolls, coffee etc) will be managed by the RAF who will be based in the ’30-130 paddock’
Litter:
It is ABSOLUTELY IMPERATIVE that no litter or cigarette ends are dropped anywhere other than a bin. Failure to observe this very simple rule seriously jeopardises us being invited back, so please use the bins provided (or your pockets!).  Anyone seen dropping litter will be escorted offsite
Spectators:
All spectators must come with drivers already booked in – a maximum of 4 per vehicle – and have been registered by the driver they are attending with on the day.  All spectators must also bring photographic ID with them on the day or they won’t be allowed in
Volunteers:
We need a handful of people to help with putting the V-Boxes in the cars and changing over memory cards throughout the day, so please PM me or Mechell if you’re interested in helping and include your email address
Video Cameras:
All video cameras must be securely mounted internally via suction mount or bolted to a rollcage. No hand held cameras are allowed. All footage must be for personal use only – eg: not uploaded to YouTube, forums etc
Photography:
Due to the extremely sensitive nature of the venue, cameras are only permitted for personal use, eg: photos cannot be posted on forum or websites. No professional or commercial photography is allowed
Marshals & Emergency Cover:
The event will be fully marshalled and include Medical and Fire Cover
Rides:
30-130 wouldn’t happen without the help of the RAF volunteers who marshal and support the event– all of whom are petrolheads and would sell their sister (or brother) for the chance to own the cars attending the day. If you’re happy to give them a ride we will give you a sticker for your windscreen so the guys know they can jump in with you sometime during the day. Thanks in advance from me - it's good to be able to give something back
Reserves:
If places sell out before the deadline a reserve list will be started (we will need your name, email and phone details) and any places that become available offered to reserves in order
Cancellations:
Please tell Mechell or Darin if you cannot attend for any reason. Please DO NOT post on the Forum offering your place to someone else as we need to manage the entry list for security purposes and they won’t have registered. Please be aware of the MLR's Cancellation Policy
Sunday 24th March– All Marque 30-130 Day
If for any reason you can’t attend the MLR 30-130 day on Saturday, we will be running another for all other marques on Sunday which you’d be welcome to book. Same details and costs apply
Last but not least:
A huge thankyou to George, his staff and the RAF Marham Station Commander who continue to make this event possible.
Offline DanGB
  • Different
Re: 30-130 day at RAF Marham 24th March
« Reply #1 on: December 28, 2012, 02:53:21 pm »
Yes please!
Seat Leon Mk2 TFSI sport 4WD sleeper - Breaking
Buld thread: http://www.mk5golfgti.co.uk/forum/index.php/topic,45377.0.html
Offline Poverty
  • -Given: 36
  • -Receive: 21
« Reply #2 on: December 28, 2012, 03:01:47 pm »
1. Poverty
Offline Northerner
« Reply #3 on: December 28, 2012, 03:04:34 pm »
I might bring my mini to this
Offline DanGB
  • Different
« Reply #4 on: December 28, 2012, 03:07:30 pm »
Offline RENNTAG
  • Premium Performance Parts
« Reply #5 on: December 28, 2012, 03:13:27 pm »
1. Poverty
2. DanGB
2. Bendy
I cant find the thread on the MLR forum? has somone got a link to it?
Offline mechell
« Reply #6 on: December 28, 2012, 03:17:20 pm »
Please do :D  I have one and would be good to see how it goes
Here is the link to the site
http://www.lancerregister.com/showthread.php?t=437754
Offline Poverty
  • -Given: 36
  • -Receive: 21
« Reply #7 on: December 28, 2012, 03:20:20 pm »
1. Poverty TTRS
2. Dangb Leon BT
3. Bendy GTI
4. jonnyc TTRS
5.  Cuprak1
6. Yaz 996TT BT
7. Ishrs TTRS
8. Ray zed 350z charged
9. Cliff Brabus
Offline Sunglasses Ron
« Reply #8 on: December 28, 2012, 03:24:39 pm »
Standard attendance for me..  :happy2: Might be in the old man's Merc this year though.
Offline Poverty
  • -Given: 36
  • -Receive: 21
« Reply #9 on: December 29, 2012, 02:51:04 pm »
Get your names down lads, its a popular event. Payments begin from the 7th of Jan. I'll update the list as people put down their names and then pay also, so we know who is going. Alot of VAG's as usual!
1. Poverty - TTRS
2. Dangb - Leon BT
3. Bendy - GTI
4. jonnyc - TTRS
5.  Cuprak1 - Unknown car, needs to buy one
6. Yaz -  996TT BT
7. Ishrs - TTRS
8. Ray zed - 350z charged
9. Cliff - Brabus
10. Sunglasses Ron C63 AMG
11. Vincent - R8 V10 stock
12. Nudebut - R8 V10TT
13. Keith - APR S3 GolfR (MAYBE)
14. Richard W - R8 V10 S2
15. Graeme C - MK2 LCR
16. Harrison C - TTRS
17. AndrewJB - MK2 LCR
18. George W - s2000 BT
19. Brett - B5 S4 Stage3
20. David C - MK2 Leon k04
21 Andy D - GTR stage 3
22. Matt M - GTR stage2/3
23. Frankie - FI DC5 integra
24. Henry H - Evo 8 BT.
25. Rui C - 225hp EP3 Type R
26. AKA DK - R8 V10 Twin supercharged.
27. Graham - B8 S4
29. toot3954 - TTRS
30. Dace -
« Reply #10 on: December 29, 2012, 03:05:20 pm »
I've let the JKM guys know.  :happy2:
Offline chungster
« Reply #11 on: December 29, 2012, 03:11:18 pm »
Hurdy / Stattlers going too I hope!!
Offline s3dubbin
« Reply #12 on: December 29, 2012, 06:54:39 pm »
Can somebody do me a favour and add my name please, a little useless on the comp - s3dubbin s3 8p BT.
Thanks a lot, Stevie.  :happy2:
Offline jonnym
  • -Given: 40
« Reply #13 on: December 29, 2012, 09:43:30 pm »
One of my best mates is an officer based at Marham and helping co-ordinate this....he's telling me the events already look VERY good.
See we're i'm being sent in Jan, then i'll be able to say yay or nay.
« Reply #14 on: December 30, 2012, 08:45:25 am »
1. Poverty - TTRS
2. Dangb - Leon BT
3. Bendy - GTI
4. jonnyc - TTRS
6. Yaz -  996TT BT
7. Ishrs - TTRS
9. Cliff - Brabus
27. Graham - B8 S4
29. toot3954 - TTRS
30. Dace -
31. Hurdy - Golf R
32. Steve Jr (Statllers) - Porsche 997 Turbo
33. Craig K (Statllers) - Golf RS
34. Luke (Statllers ) - Ed30 L04xx
35. S3dubbin - S3 8P BT
36. Ant - Audi R8 V10
37. Scott - Evomsit 997 Turbo Tip
Added myself, Statllers crew, Ant, Scott and Stevie.
« Last Edit: December 30, 2012, 01:05:49 pm by Hurdy »
