Author Topic: ESP and Tyre pressure warning lights both on at the same time?  (Read 16246 times)
Offline CMB
« on: December 31, 2012, 03:37:13 pm »
Within about 5 minutes of setting off yesterday the ESC and tyre pressure lights came on at the same time, so i went to the nearest petrol station and checked all my tyres pressure, some were a little off so corrected them all using the auto air, got back in and reset the the pressure by holding the button in front of the gear stick until i heard the "bong" the lights didn't come on when i started the car so i thought it was all good then within another 5 minutes of driving they both came back on? Ive had a look around on the net and haven't seen much info on this? Can anyone help? Also my exhaust warning lamp came on last week but went off and hasn't been back on since, could this of just been dodgy petrol or could the two be linked and it could be something to do with the electrics? Any help would be appreciated, I'm a student so don't have a lot of money to be taking i to VW to charge me £100 just for having a look.
« Last Edit: January 04, 2013, 02:03:01 am by breslin91 »
Offline Baz300
Re: ESC and Tyre pressure warning lights both on at the same time?
« Reply #1 on: December 31, 2012, 03:51:02 pm »
Try contacting the nearest member to you in this list
http://www.mk5golfgti.co.uk/forum/index.php/topic,120.0.html
There might be some fault coded stored.
When I had both the lights on together it was a wheel bearing that needed replacing.
Offline valvedoctor
« Reply #2 on: January 02, 2013, 05:03:21 pm »
Hiya mate, I had both these lights on a month back and it turned out to be a rear wheel sensor.got a new sensor fitted while it was been serviced. Been fine since :happy2:
Offline donovan2123
« Reply #3 on: January 02, 2013, 08:36:14 pm »
Again sa lights and again wheel bearing. Becoming a commontthing. The abs ring rusts and the sensor struggles to keep a signal
Offline brough74
« Reply #4 on: January 02, 2013, 08:43:09 pm »
I agree either a sensor or wheel bearing, ive just had this problem myself and after trying a new sensor it turned out to be a wheel bearing as the sensor ring had rusted.
You need it scanned then you know what side to check, a word of warning though buy a genuine VW sensor if you need one. As after market ones do not read correct wheel speeds.
PEARL DIAMOND BLACK 3dr GTI
HEATED LEATHER,MULTI FUNCTION WHEEL,
18” MONZA ALLOYS, XENON HEADLIGHTS, FLAT TYRE INDICATOR
LUX PACK AND WINTER PACK
SHARAN AERIAL, GTI TAX DISC HOLDER, R32 REAR LIGHTS
VW RACING FRONT SPOILER
Offline donovan2123
« Reply #5 on: January 02, 2013, 08:45:58 pm »
Ditto above. If it's a sensor the speed will be out completely to other wheel speeds.
If it's the bearing the speed sensor will keep dropping speed whilst others stay at same speed I.e. I all others will be 15kmh and suddenly the dodgy side will drop to 5kmh then back up to 15kmh.
Offline CMB
« Reply #6 on: January 04, 2013, 02:02:35 am »
Thanks for the replies. I meant ESP, just realised now, is that what you all thought i meant anyway? If so, how much is a new sensor or bearing roughly? Cheers
Offline brough74
Re: ESP and Tyre pressure warning lights both on at the same time?
« Reply #7 on: January 04, 2013, 10:52:29 am »
A new sensor from VW is £71 roughly, and buy genuine ones as ive already said. As for bearings there are 2 sizes at 30mm and 32 mm and you dont know which size you have to you remove the old on. These are from £40 to £135 for genuine ones but replacement ones work fine.
If you are going to do it yourself you will need a M14 and M18 spline bits to remove the caliper and then the bearing. Easy to do just a bit fiddly
Hope all this helps, as me and donovan2123 have just had the same problems
Offline donovan2123
« Reply #8 on: January 04, 2013, 11:11:26 am »
Torque the hub bolt at 180nm + 180 degree extra turn. This is what's listed on auto data
fraz-mk5
« Reply #9 on: January 04, 2013, 05:33:29 pm »
hi guys i just had the same problem with the sensors and it turned out to be a wheel bearing and sensor. so got it changed yesterday but the lights havent went out. so dont no if they need to be reset but now its bringing up the stearing light and the engine management light which i cant understand
any ideas
Offline CMB
« Reply #10 on: January 04, 2013, 06:38:05 pm »
Cheers lads, if its plugged into VAG-COM will that tell me exactly which wheel and what the problem is or is it not that easy?
