Author Topic: what controls my dv  (Read 1736 times)
Offline pd9264
what controls my dv
« on: January 06, 2013, 06:34:27 pm »
what controls the dv. because mines not operating causing a flutter. iv tried 3 that i knowwork so cant be a faulty dv.
Offline SteveP
  • -Given: 117
  • -Receive: 341
    • My Project
Re: what controls my dv
« Reply #1 on: January 06, 2013, 07:41:49 pm »
What other mods are you running as a fluttering noise is normal if you have other mods like a intake.
Offline pd9264
« Reply #2 on: January 06, 2013, 07:54:14 pm »
im talking serious flutter my dv isnt working at all. iv replaced it with different ones and still nothing. iv just fitted k04 ready for map. gona do injecters 2mora. but thought i would just check car after fitting turbo. so gave it a rev and it flutters bad checked dv as its at front now buy pulling pipe of the side. and it isnt moving at all. just want to make sure everything is sweet before getting stage 3 file.
  i bought a used k04 and im hoping it isnt a stuck wastegate or something like that.
Offline rubber toe
« Reply #3 on: January 06, 2013, 08:01:06 pm »
Have you rechecked your wiring to the dv since you've extended them ?
  • -Receive: 453
« Reply #4 on: January 06, 2013, 08:03:40 pm »
If you don't have a k04 map installed then keep engine off boost as with a k03 map the turbo will overboost.
Offline pd9264
« Reply #5 on: January 06, 2013, 08:06:41 pm »
so do you think when i get the map uploaded it will be fine.
also iv just pulled the wire back to the front of the car and plugged in
   iv also reverted my stage 2+ map back to revo stock settings
« Reply #6 on: January 06, 2013, 08:14:36 pm »
There was a chap on here called Sammy.
He did exactly as you have done. I sincerely hope you haven't been caning it as it cost him an engine.  :rolleye:
Offline pd9264
« Reply #7 on: January 06, 2013, 08:16:49 pm »
no i havent been driveing the vehicle just started her up to check it worked. but like i say dv not working at all.
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 249
« Reply #8 on: January 06, 2013, 08:23:49 pm »
Where are you getting it mapped??
If your taking it to a specialist then they are best placed to check it over, remember your engine is trying to control a different turbo to what it's programmed to do so it's not going to to work quite right as it is.
Offline Scrubadub
  • Soon to be "bagged"
« Reply #9 on: January 06, 2013, 08:28:00 pm »
Flutter is normally caused by the actuator? Mine does it even with dump valve working
Fun bags
Offline pd9264
« Reply #10 on: January 08, 2013, 08:25:36 pm »
i found the cause of the dv not opening up and diverting. when i fitted the dv reroute i left the old map sensor that was already in the pipe. didnt think anything of it.
   so i removed the map sensor from my old pipe and fitted it in the new dv reroute. and now the flutter is gone and dv is operating as it should.
 just gota book into aps for my stage 3 file and im going to get them to fit the injectors aswell. dnt want to risk it.
Offline james
« Reply #11 on: January 08, 2013, 09:10:59 pm »
It will chatter alot due to the load request on the k03 map.  Dont rev the car at all untill it is mapped.
