Author Topic: boot pop kit problem  (Read 6119 times)
Offline scottm72
« on: February 03, 2013, 10:35:37 pm »
After getting the boot pop coded a week ago i finally got around to installing the parts today.
Got one problem though, the rubber buffers dont appear to be popping out enough ?
If i park on a flat surface it just about pops enough to completelly open the boot, if on slight up facing hill it works great !!!
I watched ecs tunings video on install and the only thing that came to my attention is when he installed the rubber buffers and it stated that you turn the allen key anti clockwise until it stops ! ( mine didnt stop and just turned forever )
then you push the buffer in before turning the allen key clockwise until again it stops ! ( again mine didnt stop just got tighter but would keep turning indefinatelly if i try to ) !!!
so i thought that was it done and it pushes in and out very well, no way of telling if it was at its maximum compression setting though,
I am assuming that due to my problem the buffers just arent strong enough, or big enough and it just needs a slightly bigger pop before the boot takes over and flings it open.
After it does pop i just need to pull the boot an inch or so then it flies open so the other parts appear to be doing their job.
I got the kit from rainsworth skoda and it came as the complete kit of which they have sold loads off, the part number for the buffers is z1k8827761d,
would appreciate if anyone had any advice on this or know if maybe they have sent me the part for a lighter tail gate or something
many thanks
Offline Kalpsn2000
  • -Receive: 56
Re: boot pop kit problem
« Reply #1 on: February 03, 2013, 11:12:01 pm »
I did this mod a few weeks ago but it doesn't work that well...I've read its due to the cold.
Offline scottm72
« Reply #2 on: February 03, 2013, 11:14:40 pm »
so are you having the same problems as i am then,
if its the buffers im thinking that maybe ones with a larger compression rate would solve the problem
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #3 on: February 03, 2013, 11:16:54 pm »
did you grease the ball sockets?
Cluster and Key coding
Location Great Yarmouth
Offline scottm72
« Reply #4 on: February 03, 2013, 11:23:05 pm »
emmm nope  :ashamed:
now that i think about it the old ones where full of white grease
doh silly me, i will do that tomorrow
dont have any white grease, can you use anything else ?
come to think of it what is that white grease stuff actually called as i should have a tub for things like this
cheers eddie  :happy2:
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #5 on: February 04, 2013, 11:16:00 am »
I used normal grease, shouldn't make a difference for this mod
The white grease probably is white lithium grease ( use that on your door locks and hinges )
Offline camfollower
  • -Receive: 31
  • Cam follower awareness.
« Reply #6 on: February 04, 2013, 11:21:23 am »
Come to think of it, don't think I greased mine either... it worked once, then hasn't worked since, but I did install in December.
Will grease them up.
Incidentally, how many notches on the bump stop are you guys using?
Offline scottm72
« Reply #7 on: February 04, 2013, 11:57:31 am »
lol neither of us using the grease, lets see if that works.
with regards to the bump stop, i cant set it at all, going by the ecs tuning video you allen key it anti clockwise until it stops, then push it in, then turn it clockwise until it stops ?
mine doesnt stop turning either way ???
i called skoda and they assured me the part number i have is correct but im thinking am i doing something wrong here.
when you installed the bumps did yours stop turning as described ?
i am not sure if i have maximum compression or not but im thinking if the stops are set correctly there doesnt appear to be enough whoomph in order to get the struts to then take over and completelly open the boot ?
will try to grease up and report back.
« Last Edit: February 04, 2013, 12:37:10 pm by scottm72 »
Offline Kalpsn2000
  • -Receive: 56
« Reply #8 on: February 04, 2013, 12:14:21 pm »
I didn't put grease on mine either but didn't think that would make much difference.
My bump stops did stop turning in both directions with the allen key. Currently mine are at the lowest setting. I think I will bring them out 1-2 clicks to see if that helps.
Offline scottm72
« Reply #9 on: February 04, 2013, 12:15:06 pm »
bingo, watched your vid, that is the problem i am having, on your vid the boot JUST opens and you are on a flat surface, slight hill and it wont work same as mine.
this isnt right, will grease parts up and hopefully better.
i cant post vids yet as im stupid lol but if you grease yours up can you post a vid in same parking space to see if it helps.
Offline scottm72
« Reply #10 on: February 04, 2013, 12:38:57 pm »
hmmm thinking i might have dodgy bumps, do you know if the part number is the same as mine which is posted in the opening comment ?
thanks
Offline scottm72
« Reply #11 on: February 04, 2013, 12:50:01 pm »
white lithium grease thats what its called, will buy some, cheers for that eddie, thanks posted  :happy2:
Offline scopes
  • -Given: 131
  • -Receive: 116
  • Wolfsburg Edition
    • My GTI
« Reply #12 on: February 04, 2013, 12:54:32 pm »
I had some white grease on mine, but went to check anyways, give it a spary with some fluid chain grease Structovis BHD stuff we have here in work.
Guess what, it pops all the way up now, no problem. lol
 :drinking:
I must not have had enough grease on in the first place, i dunno. But it works ok now.
Silver is the way !
Offline Kalpsn2000
  • -Receive: 56
« Reply #13 on: February 04, 2013, 01:41:59 pm »
thanks
Yes mine are the same part number :happy2:
Offline Kalpsn2000
  • -Receive: 56
« Reply #14 on: February 04, 2013, 01:45:11 pm »
 :drinking:
Does it work the 1st time you try to open it? As in 1st try in the morning?
Mine does work if I have just closed the boot. The strut gas must get warmed up so then works fine the 2nd time.
But think I will put some grease on anyway. Also I have read you have to be careful with what grease/oil you use as some eat plastic?
