Author Topic: would you pay this  (Read 13270 times)
would you pay this
« on: July 12, 2009, 09:57:30 pm »
Re: would you pay this
« Reply #1 on: July 12, 2009, 10:01:34 pm »
uber uber rare
£50k new
it's not an ugly price
« Reply #2 on: July 12, 2009, 10:03:21 pm »
i take it they come from the factory like this vc
« Reply #3 on: July 12, 2009, 10:04:12 pm »
that's about as far away from the factory spec as you could tastefully throw one  :grin:
Offline ukdub
« Reply #4 on: July 12, 2009, 10:05:34 pm »
I think the car would be worth more realistic money (ie not 40k) if it was a standard car.  We can all relate to modifying cars, but to do it to such a rare car is daft.
Laser Blue with K04 power, APR hardware controlled by REVO 2+ software
Chassis by KW V3's, Whiteline and a hint of PRO race 1.2's
Brakes by Brembo 4 pots
« Reply #5 on: July 12, 2009, 10:07:33 pm »
i know, the rsi is taboo, some cars you just shouldn't play with, its been done well, but i for one would relish a car like that far more if it was totally box fresh and un pimped
« Reply #6 on: July 12, 2009, 10:09:32 pm »
that said, if i owned one it would get wrapped like this within hours of delivery  8)
« Reply #7 on: July 12, 2009, 10:10:05 pm »
just says in the advert 115 of 250
Offline neg
  • gone old skool
« Reply #8 on: July 12, 2009, 10:12:40 pm »
Wasnt the RSI the only one with the V6 and 4motion ... makes it the best base for the upgrade they have done.
Offline SteveP
  • -Given: 117
  • -Receive: 341
    • My Project
« Reply #9 on: July 12, 2009, 10:13:16 pm »
That's before he gave it the HPA turbo treatment  :laugh: :laugh:
« Reply #10 on: July 12, 2009, 10:14:08 pm »
i must put my brain in gear :signLOL:
« Reply #11 on: July 12, 2009, 10:14:30 pm »
2000 Volkswagen Beetle RSi   See all Volkswagen models
Wheelbase   2513 mm   98.9 in
Track   front   1553 mm   61.1 in
rear   1553 mm   61.1 in
Length   4100 mm   161.4 in
Width   1810 mm   71.3 in
Height   1475 mm   58.1 in
Length:wheelbase ratio   1.63
Ground clearance
Kerb weight   1515 kg   3340 lb
Weight distribution
(Front)
Fuel capacity   63 litres   13.9 UK Gal   16.6 US Gal
aerodynamics
Drag coefficient   0.400
Frontal area   2.23 m2
Cx   0.89
engine
Bore × stroke   84.00 mm × 95.90 mm
3.31 in × 3.78 in
Cylinders   V-6 in 15.0° vee
Displacement   3.2 litre
3189 cc
(194.605 cu in)
Type   DOHC
Key: SOHCSingle overhead camshaft DOHCDouble overhead camshaft OHVOverhead valves TSTwo stroke SVSide valves SlSleeve valves oiseOverhead inlet side exhaust See more...
4 valves per cylinder
24 valves in total
Construction
Sump
Compression ratio   10.80:1
Fuel system   MPFi
Maximum power   224.1 PS (221.0 bhp) (164.8 kW)
@ 6200 rpm
Specific output   69.3 bhp/litre
1.14 bhp/cu in
Maximum torque   320.0 Nm (236 ft·lb) (32.6 kgm)
@ 3000 rpm
bmep   1261 kPa (182.9 psi)
Specific torque   100.34 Nm/litre
Maximum rpm
Manufacturer   Volkswagen
Code
Main bearings   7
Coolant   Water
Bore/stroke ratio   0.88
Unitary capacity   531.5 cc/cylinder
Aspiration   Normal
Compressor type   N/A
Intercooler   None
Catalytic converter   Y
performance
0-50 mph (80 km/h)   4.70 s
0-60 mph
0-100 km/h   6.40 s
0-100 mph
80-120 km/h (50-70 mph) in top
Standing ¼mile   14.80 s
Standing km   27.40 s
Top speed   225 km/h (140 mph)
Fuel consumption   16.7/9.2/11.9 l/100km urban/extra-urban/total
CO2 Emissions   286.0 g/km
Carfolio Calculated CO2 ?
Power-to-weight   145.87 bhp/ton
chassis
Engine location   Front
Engine alignment   Transverse
Drive   AWD
Key: FWDFront wheel drive RWDRear wheel drive AWDAll wheel drive 4WDFour wheel drive
Steering
Turns lock-to-lock
Turning circle   10.90 m
Suspension   front   I.MS.ARB.
rear   I.DW.TA.CS.ARB.
Key: IIndependent LALive axle dDde Dion axle WWishbone DWDouble wishbones CSCoil springs ARBAnti-roll bar LSLeaf springs SESemi-elliptic leaf springs See more...
Wheels   front   9J x 18
rear   9J x 18
Tyres   front   235/40 R 18 Z
rear   235/40 R 18 Z
Brakes F/R   VeDi/VeDi-S-ABS
Key: VeVentilated DiDisc (Disk) DrDrum SServo-assisted ABSAnti-lock Braking System
Brake ∅   front   334 mm
rear   256 mm
Braked area
Transmission   6M
Top gear ratio   0.77
Final drive ratio   4.20
general
RAC rating   26.2
Number made
Model code
Model family
Insurance classification   No information available
Tax band   No information available
2000 Volkswagen Beetle RSi added 2001-03-11.
Last modified 2008-04-03.
« Reply #12 on: July 12, 2009, 10:15:27 pm »
Too rare and special to modify in my opinion.
Price is only the result of supply vs demand. Nothing is too expensive unless you don't have the money.
Offline SteveP
  • -Given: 117
  • -Receive: 341
    • My Project
« Reply #13 on: July 12, 2009, 10:15:53 pm »
Ground clearance
Weight distribution
(Front)
aerodynamics
Cx   0.89
engine
3.31 in × 3.78 in
3189 cc
(194.605 cu in)
Type   DOHC
24 valves in total
Construction
Sump
Fuel system   MPFi
@ 6200 rpm
1.14 bhp/cu in
@ 3000 rpm
Maximum rpm
Code
Main bearings   7
Coolant   Water
Aspiration   Normal
Compressor type   N/A
Intercooler   None
performance
0-60 mph
0-100 km/h   6.40 s
0-100 mph
Standing km   27.40 s
chassis
Drive   AWD
Steering
Turns lock-to-lock
rear   9J x 18
rear   235/40 R 18 Z
rear   256 mm
Braked area
Transmission   6M
Top gear ratio   0.77
general
RAC rating   26.2
Number made
Model code
Model family
^^^ And they call me a geek  :signLOL: :signLOL:
« Reply #14 on: July 12, 2009, 10:16:54 pm »
^^^   :laugh:
if i had the money i would have one in my stables  :innocent:
slower than you would think from stock but the handling characteristics of a housefly  :evilgrin:
