Author Topic: Koni FSD+F1 Assy Problems  (Read 1042 times)
Offline Beeps
« on: February 06, 2013, 05:00:59 pm »
Calling anyone on FSDs!
I have a Mkv GTi on standard springs (did not want to go lower) and FSDs. I put on F1 Assymetrics at the same time as the shocks and since then I have been fighting to keep it within a lane on a motorway! It feels like it has toe-out even though I have had it checked twice with full 4 wheel alignment at different places and 4 garages have now tested it for steering play - it randomly tramlines off line. I have tried changing the tyre pressures by plus/minus 2 psi but it does not cure the dead feeling when straight ahead. Once cornering it feels ok, but wheel central has no feel to it, every gust of wind moves the car and you feel you are driving a van!
The car handled great before the mod but was a bit rough for the family.
So, do you think I have a shock problem or are the soft walls of the F1s not suited to the FSDs?
I did 50k on my mk4 with FSDs and GSD3s and loved it - the Mkv is a disappointment at the moment.
Do I change the tyres or the shocks? Are the standard springs not suited to FSDs? Help please!
Offline mad_pete
Re: Koni FSD+F1 Assy Problems
« Reply #1 on: February 06, 2013, 06:40:02 pm »
I have that setup and it's fine for me. That is to say FSDs on stock springs with f1 asymmetrics sometimes I find the car can fight between the tramlines given a sense of loose steering although that's my merc rather than the golf.
Offline Beeps
« Reply #2 on: February 06, 2013, 07:38:08 pm »
Thanks Mad_Pete,  yes it does feel "loose" and I do not know if it is the tyres or the shocks.
  • -Receive: 453
« Reply #3 on: February 06, 2013, 07:53:59 pm »
Are your tyres installed correctly? You have to have the 'outside' label on the outside...
Offline mad_pete
« Reply #4 on: February 06, 2013, 09:35:25 pm »
Shocks shouldn't make the straight line steering wobbly, I'd say something is loose. Got any mates with a spare set of wheels as that's any easy test.
Offline paulk
« Reply #5 on: February 06, 2013, 09:37:27 pm »
i had thoses f1 on my vxr , tramlined and pulled me all over the road , problems went away when the tyres did ...
