Author Topic: Help With Canbus Please  (Read 4981 times)
Offline scopes
  • -Given: 131
  • -Receive: 116
  • Wolfsburg Edition
    • My GTI
« on: February 09, 2013, 05:39:37 pm »
Just fitted a new canbus for the rns510 but got this:-
Address 19: CAN Gateway (J533)       Labels: 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 C    HW: 1K0 907 951
   Component: J533  Gateway H37 0614
   Revision:   H37       Serial number: 250511F1000760
   Coding: 350001
   Shop #: WSC 12345 123 12345
   VCID: 306B46846336519891C
1 Fault Found:
01044 - Control Module Incorrectly Coded
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 1
                    Fault Frequency: 9
                    Mileage: 71445 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:00:01
can anybody help me please...  :happy2:
Silver is the way !
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
Re: Help With Canbus Please
« Reply #1 on: February 09, 2013, 05:49:51 pm »
Is that the only error.
Did you make a note of the old settings selected before fitting the new Gateway, have you checked the correct options have been selected?
Offline scopes
  • -Given: 131
  • -Receive: 116
  • Wolfsburg Edition
    • My GTI
« Reply #2 on: February 09, 2013, 05:50:43 pm »
Yes mate, but scopes goes to double check... it for a friend too
Silver is the way !
Offline scopes
  • -Given: 131
  • -Receive: 116
  • Wolfsburg Edition
    • My GTI
« Reply #3 on: February 09, 2013, 05:56:48 pm »
Yes doubled checked as i had printed screens... everything that was ticked was ticked... Anything else?
thanks in advance guys
Silver is the way !
Offline jbc
« Reply #4 on: February 09, 2013, 06:20:51 pm »
Have you checked all the long coding options are the same as before or just the installation list?
2012 Mk6 GTD. Tornado Red. TPMS, RNS510 and reverse camera retrofit.
Offline scopes
  • -Given: 131
  • -Receive: 116
  • Wolfsburg Edition
    • My GTI
« Reply #5 on: February 09, 2013, 06:25:28 pm »
How?
Silver is the way !
Offline scopes
  • -Given: 131
  • -Receive: 116
  • Wolfsburg Edition
    • My GTI
« Reply #6 on: February 09, 2013, 06:26:13 pm »
Silver is the way !
Offline jbc
« Reply #7 on: February 09, 2013, 06:37:58 pm »
I changed my Canbus about 4 years ago so I'm having trouble remembering the detail, but I have a vague recollection that the car "forgets" it a right hand drive etc so you have to set this in Coding-07 > Long Coding Helper. I've emailed you my VCDS screenshots when I did mine in case they help in some way.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #8 on: February 09, 2013, 06:43:50 pm »
is this what the panic is about :signLOL:
tbh. if you get this fault it is because you have either missed something or added something
Commom mistakes are
Driver Electric instead of Door Drivers
Digital Radio
Air Con Compressor
I suggest that you double check the tick boxes, do a complete scan and compare it to the boxes you have ticked
The long coding won't cause that fault
Cluster and Key coding
Location Great Yarmouth
  • -Receive: 453
« Reply #9 on: February 09, 2013, 06:48:04 pm »
I'm guessing he hasn't checked address 04 for steering angle as in the earlier gateway it was 00.
Offline scopes
  • -Given: 131
  • -Receive: 116
  • Wolfsburg Edition
    • My GTI
« Reply #10 on: February 09, 2013, 06:49:31 pm »
^^^b yes funny i seem to think that is the problem, what do i need to do there
everything else is ticked correctly
Silver is the way !
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #11 on: February 09, 2013, 06:51:06 pm »
That is another common item
Offline scopes
  • -Given: 131
  • -Receive: 116
  • Wolfsburg Edition
    • My GTI
« Reply #12 on: February 09, 2013, 06:51:38 pm »
Hey Guys
Sorted big thanks for all your help, thats what it was...   :happy2:
Silver is the way !
Offline jbc
« Reply #13 on: February 09, 2013, 06:55:49 pm »
I knew someone more knowledgeable than me would turn up eventually!
Hey Guys
Glad you've managed to fix it.
  • -Receive: 453
« Reply #14 on: February 09, 2013, 06:59:45 pm »
Hey Guys
