Author Topic: RCD310 question...  (Read 924 times)
Offline itsmeGAV
RCD310 question...
« on: February 09, 2013, 08:52:19 pm »
I'm a tad confused, brought a MK5 with an RCD310, all I know is its from a 2009 model, and mine is a 2004 model. When I turn the ignition, it doesn't automatically boot. What could be causing this?
Cheers!
Offline trs888
  • -Given: 17
  • -Receive: 20
Re: RCD310 question...
« Reply #1 on: February 09, 2013, 11:55:51 pm »
does it work when you turn the head unit on?
does it turn off with the car?
maybe if its previously had an RNS510 or other head unit in previously and the previous owner has swaped it before selling it might be a loose wire possibly?
or could be a coding issue?
Offline itsmeGAV
« Reply #2 on: February 10, 2013, 11:51:37 pm »
It works when I press the on button, but ONLY when ignition is turned or engine is on.
It turns off with the car yes.
Could be either, not sure.  :confused:
