Author Topic: ** Climair wind deflectors ( 3door ) **  (Read 46830 times)
« on: July 15, 2009, 12:24:56 pm »
Noting here that this review is for the 3dr and not the 5dr so i wont be covering the rear deflectors, you have to order the rear separately.
i bought mine from here: http://www.palmautomotive.co.uk/ at a cost of £44.95 delivered
i know these will not be to 99% of peoples taste but they look pretty flush on the car, and the fitment is good.
so what do you get for your money?
well basically nothing more than this:
so here's how to fit them, should take no more than 10-20 seconds per side, easy to just pop them in and out as you need to if the window's down
start by lowering the windows
it's very apparent which side is which, start by placing the lower corner or the deflectors edge into the lower corner of the bottom of the window frame
it's vital that the edge sits on top of the window rubber..not inside it, like so...
whilst maintaining slight but not heavy downward pressure, locate the top edge of the deflector inside the window frame
keeping a hold of it as you don't want to drop it and scratch it we move to the other end and we're aiming to go inside the frame at the top here too, tucking into the frame.
gentle apply pressure towards the front of the car and allow the deflector to bow outwards
now using 2 hands (i didn't cos i was holding the camera) start in the center and work to the sides both left and right at the same time, tipping and pushing at the same time and the deflector will happily slide home inside the frame
put the windows up and down a few times to make sure they're seated ok
The results:
a bit closer, they sit very nice and flush and puff the sides of the car out a little, oh and nice and OEM looking once i rid them of that little blue transfer
side profile
dead flat  8)
further back
from inside
all important window down view
the window just catches so makes a click noise but that will go after the windows been up and down a few times
Questions i know you want to hear:
Do they stop the rain dripping in from the roof?
yup.
What are these like at speed?
I've had no worries at all, all the way up to the speed limit and back, nice and quiet
How is it with the sunshine roof open? Does it still release the cabin pressure waves?
Yes it does, the cabin is quieter with the front windows down just a touch too whereas before the air just came flying in
Verdict
  • Nice Light Smoke in colour
  • Improves Ventilation And Airflow For More Comfort
  • Tough Acrylic Material
  • Custom Moulded Aerodynamic Styling so not fat and 4x4ish
  • Easy Secure Fit into Window seals - not the low quality glued on type
  • Compression fitment so very fast to take on and off
Hope this helps  :happy2:
Peace.
VC  :smiley:
« Last Edit: July 15, 2009, 11:36:21 pm by Very Cherry »
Re: ** Climair wind deflectors ( 3door ) ** by Very Cherry
« Reply #1 on: July 15, 2009, 06:00:14 pm »
Excellent!
I want some of these and your review answers all my questions and illustrates very well how to install them.
:drinking:
« Reply #2 on: July 15, 2009, 06:23:02 pm »
Do those little blue stickers look easy to remove?
« Reply #3 on: July 15, 2009, 07:04:04 pm »
they're just a very thin vinyl so will come off easy, just not got around to it  :happy2:
« Reply #4 on: July 15, 2009, 10:42:03 pm »
Do likie these!  :happy2:
70's FTW!  :jumpmove:
« Reply #5 on: July 15, 2009, 10:56:37 pm »
....More 1970s style : -
I could post many more, but.
The 1970s wind deflectors were always clear plastic though, and usually turned yellow after a while.
Offline gazbutS3
« Reply #6 on: July 15, 2009, 11:30:57 pm »
look top notch them VC, u motors cryin out for a tap with the lowering stick :smiley:
Online john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #7 on: July 16, 2009, 12:01:10 am »
not my taste VC , however another informative and thorough writeup  :happy2:
Red ED35 5dr DSG
BLOG | BUILD
Offline Moschops
  • -Given: 118
  • Edition 30 No 2275
« Reply #8 on: July 17, 2009, 09:34:22 pm »
Top notch review...good man... :happy2:
Cheers,
Wayne
Offline celica
« Reply #9 on: July 26, 2009, 09:12:45 pm »
wouldn't mind these on the 5dr
tend to have the windows opened more often than not, so wind noise and water droplets come through
but expensive plastic
MKV Golf DSG
Phil Mcavity
« Reply #10 on: July 26, 2009, 10:02:47 pm »
Blinds in the Back sort that out Celica, apart from the front where there is no blind to stop wind and rain intrusion. :happy2:
Offline celica
« Reply #11 on: July 27, 2009, 08:07:45 pm »
very true
do you have these on a 5dr but front windows only?
if so any pics?
MKV Golf DSG
Phil Mcavity
« Reply #12 on: July 27, 2009, 08:55:05 pm »
No, not as yet , but will be added with my new list of bits for Phylis in the coming months :happy2:
« Reply #13 on: July 27, 2009, 09:20:36 pm »
I'm about to order some for my 5-door and was thinking whether to just have the fronts, but when I have my sunroof open I usually drop the rear windows an inch to release the cabin pressure waves. So, in other words, I'l doubtless go for a full set.
However, I can easily fit the fronts first and then take pics before adding the rears.
Offline TomB
« Reply #14 on: July 27, 2009, 10:06:36 pm »
They're sweet, I'm definately ordering a set of these!  Nothing worse than getting wet with the windows down a touch.
Top review and great pics, many thanks!  One question though, does it ever make your anti-pinch mechanism come on and force the windows down?
« Last Edit: July 27, 2009, 10:09:16 pm by TomB »
Tom
05 GTI - 18" Merc wheels, coilovers, colour coded Votex kit, all waiting to go on.
