Author Topic: Buying vag com  (Read 1870 times)
northyracing
Buying vag com
« on: March 20, 2013, 05:36:38 pm »
As tilte says I'm looking to buy myself vag com but don't know a thing about it really so would like to know where I can get it and is it possible to get any stats on what is normal readings of a standard gti as if I gets vag com and plugs it in and logs the car I ain't got a clue what's normal or abnormal
Offline chrisr763
  • -Receive: 62
Re: Buying vag com
« Reply #1 on: March 20, 2013, 05:41:24 pm »
VAG COM will set you back around £200 - £260 (New) It depends what you want to use if for. What are you thinking is wrong with your car? Is there any reason to suspect a difference from a standard GTI to yours?
northyracing
Re: Buying vag com
« Reply #2 on: March 20, 2013, 05:54:48 pm »
Basically I am having a problem with my car with it being lumpy on idle almost like a missfire but had it plugged into a snap on diagnostics and showed no fault so just wanted to log it and see if everything is running as it should be as I am stumped as I have changed all coils and plugs new DV and PCV also cam follower and still playing up
northyracing
Re: Buying vag com
« Reply #3 on: March 20, 2013, 08:02:33 pm »
Is there anywhere I could find any readings to compare my readings
northyracing
Re: Buying vag com
« Reply #4 on: March 21, 2013, 07:40:59 pm »
Anyone
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
Re: Buying vag com
« Reply #5 on: March 21, 2013, 08:13:18 pm »
Do you live near any good tuners who can log it for you?
northyracing
Re: Buying vag com
« Reply #6 on: March 21, 2013, 08:27:18 pm »
I don't really know as I am new to the vag screen so still finding my feet really I no there is storm developments like 10 miles or so away but don't know anything about them
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
Re: Buying vag com
« Reply #7 on: March 21, 2013, 08:41:05 pm »
Sure there is a thread about them in the random chat section
northyracing
Re: Buying vag com
« Reply #8 on: March 21, 2013, 09:22:55 pm »
Might just be worth taking a trip up there and see if the have vcds, wonder how much it would be to plug in
Offline bigeyd
  • -Receive: 31
Re: Buying vag com
« Reply #9 on: March 21, 2013, 10:06:44 pm »
You need a vagcom owner to help out,I have it but am miles away from Storm.
northyracing
Re: Buying vag com
« Reply #10 on: March 22, 2013, 08:02:53 am »
I no someone who own vagcom but he doesn't know what is normal reading on my car really just need to know what the correct reading of the maf sensor to rule out if it that's causing my lumpy idle
Offline bigmig95
  • -Receive: 50
Re: Buying vag com
« Reply #11 on: March 22, 2013, 10:50:47 am »
If you want your own VCDS lead I got mine from Nigel aka 'NHN' on the forum.  He's an official VAGCOM outlet and a few guys on here have purchased through him.  Very helpful guy.  :happy2:
Offline Trekmeister
  • Golf GT 140
Re: Re: Buying vag com
« Reply #12 on: March 22, 2013, 11:12:30 am »
Does Nigel have a website?
Sent from my GT-I9300 using Tapatalk 2
Offline bigmig95
  • -Receive: 50
« Reply #13 on: March 22, 2013, 11:16:07 am »
Site is under construction.
http://www.vagcom.biz/
Drop him a PM (NHN) or mail sales@vagcom.biz  :happy2:
Offline Trekmeister
  • Golf GT 140
Re: Re: Re: Re: Buying vag com
« Reply #14 on: March 22, 2013, 11:20:09 am »
Thanks for the info :)
